lsdyna cese求解器,求解过程不收敛,求路过大佬相助? 16
浏览:836 回答:3
模型二维轴对称,燃爆模拟,cese求解过程中出现温度不收敛报错,请问这是什么原因导致的?或者有什么方法能够壁面或解决这个问题,如图所示报错
参考6.7条:https://www.dynasupport.com/news/ls-dyna-r15-0-0-released-2024-02
1.Updated the nonlinear solvers used by the 0-D inflator solvers for cases where they were encountering nonlinear temperature solver errors similar to the ones encountered when using the chemically-reacting flow solver.
2.Improved the robustness of the CESE solvers in general
