- 技术邻 >
- CAE仿真 >
- HyperWorks
optistruct & hyperstudy 理论基础出现optimization has converged
浏览:42566 回答:1
** OptiStruct 11.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows 7 Workstation (Build 7600) ADMIN-PC **
** 2 CPU: Intel(R) Celeron(R) CPU G550 @ 2.60GHz **
** CPU speed 2600 MHz **
** 1327 MB RAM, 4095 MB swap **
** Build tag: 0556688_5333110_Ci32RH11M:58501-000 4000 **
** COPYRIGHT (C) 1996-2011 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: D:\Program Files\Altair\11.0.0.39/hwsolvers/hwsolver.cfg.
NOTE # 1929
Created RAM scratch area: total size 30 MB.
NOTE # 1847
AUTOMATIC SCREENING is activated.
Use "DSCREEN,AUTO,OFF" to turn off this effect.
OPTIMIZATION FILE AND PARAMETER INFORMATION :
FEM model file :
C:/Users/admin/Documents/ch.4/bracket_size_opt.fem
Output files prefix :
Model read from files:
FINITE ELEMENT MODEL DATA INFORMATION :
Total # of Grids (Structural) : 923
Total # of Elements : 804
Total # of Rigid Elements : 89
Total # of Rigid Element Constraints : 834
Total # of Degrees of Freedom : 5530
Total # of Non-zero Stiffness Terms : 139136
Element Type Information
CQUAD4 Elements : 804
Load and Boundary Information
FORCE Sets : 1
SPC Sets : 1
Material and Property Information
PSHELL Cards : 2
MAT1 Cards : 1
OPTIMIZATION PROBLEM PARAMETERS :
Objective Function : Minimize Volume
Response Summary :
Number of volume responses : 1
Number of stress responses : 1608
Static Subcase Summary :
Subcase ID SPC ID FORCE ID
1 2 1
Design Parameters Summary :
Total # of user-defined sizing design variables : 2
Total # of user-defined design variables : 2
Optimization Parameters Summary :
Maximum Number of Iterations : 30
Convergence Tolerance : 5.0000E-03
Step Size (Sizing) : 0.5000
Run Type : Sizing Optimization
Sizing Optimization Summary :
DESVAR Label Lower Design Upper
ID Bound Variable Bound
1 part1 1.000E+00 2.500E+00 2.500E+00
2 part2 -- 2.500E+00 -- *
* indicates that the design variable is directly linked
to the previous design variable
Restart from previous solution : No
Scratch file directory : ./
Free space: 32487 MB
Number of CPU processors : 1
MEMORY ESTIMATION INFORMATION :
Solver Type is: Sparse-Matrix Solver
Direct Method
Current Memory (RAM) : 41 MB
This includes ramdisk area allocated in memory : 30 MB
Estimated Minimum Memory (RAM) for Out of Core Solution : 7 MB
Recommended Memory (RAM) for Out of Core Solution : 8 MB
Recommended Memory (RAM) for In-Core Solution : 11 MB
Recommended Number of Nodes for OS SPMD Parallel Run : 1
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 4 MB
Estimated Scratch Disk Space for In-Core Solution : 18 MB
Estimated Scratch Disk Space for Out of Core Solution : 26 MB
BEGINNING OPTIMIZATION SOLUTION ....
OPTIMIZATION HISTORY INFORMATION :
ITERATION 0
(Scratch disk space usage for starting iteration = 15 MB)
(Running in-core solution)
Objective Function (Minimize VOLUM) = 4.93714E+04
Maximum Constraint Violation % = 0.00000E+00
Volume = 4.93714E+04 Mass = 0.00000E+00
Subcase Compliance
1 2.463659E+00
RETAINED RESPONSES TABLE
Response Type Response Subcase Grid/ DOF/ Response Objective Viol.
User-ID Label /RANDPS Element/ Comp Value Reference/ %
+Frqncy MID/PID/ /Reg Constraint
Mode No. Bound
1 VOLUM volume -- -- TOTL 4.937E+04 MIN
2 STRES stress1 1 421 SVM1 5.587E+01 < 1.000E+02 0.0
2 STRES stress1 1 465 SVM1 5.295E+01 < 1.000E+02 0.0
3 STRES stress2 1 63 SVM1 5.651E+01 < 1.000E+02 0.0
3 STRES stress2 1 1122 SVM2 5.679E+01 < 1.000E+02 0.0
Design Design Lower Design Upper
Variable Variable Bound Variable Bound
ID Label
note: all design variables are at their bounds
DESIGNED PROPERTY ITEMS TABLE
DVPREL1/2 USER-ID PROP-TYPE PROP-ID ITEM-CODE PROP-VALUE ANAL-VALUE
DVPREL1 1 PSHELL 2 T 2.500E+00 2.500E+00
DVPREL1 2 PSHELL 3 T 2.500E+00 2.500E+00
ITERATION 1
Objective Function (Minimize VOLUM) = 3.67715E+04 % change = -25.52
Maximum Constraint Violation % = 0.39454E-01
Volume = 3.67715E+04 Mass = 0.00000E+00
Subcase Compliance
1 4.909980E+00
Mode No. Bound
1 VOLUM volume -- -- TOTL 3.677E+04 MIN
2 STRES stress1 1 421 SVM1 9.018E+01 < 1.000E+02 0.0
2 STRES stress1 1 465 SVM1 8.306E+01 < 1.000E+02 0.0
2 STRES stress1 1 1045 SVM2 8.751E+01 < 1.000E+02 0.0
3 STRES stress2 1 63 SVM1 9.028E+01 < 1.000E+02 0.0
3 STRES stress2 1 1122 SVM2 1.000E+02 < 1.000E+02 0.0 A
ID Label
1 part1 1.000E+00 1.862E+00 2.500E+00
2 part2 -- 1.862E+00 -- *
DVPREL1 1 PSHELL 2 T 1.862E+00
DVPREL1 2 PSHELL 3 T 1.862E+00
ITERATION 2
Soft convergence criterion satisfied;
the design did not change during the last iteration.
Objective Function (Minimize VOLUM) = 3.67715E+04 % change = 0.00
Subcase Compliance
1 4.909980E+00
Mode No. Bound
ID Label
OPTIMIZATION HAS CONVERGED.
FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 41 MB
THIS INCLUDES 30 MB RAMDISK AREA ALLOCATED IN MEMORY
MAXIMUM DISK SPACE USED 19 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Fri May 16 09:55:25 2014
EXECUTION COMPLETED Fri May 16 09:55:28 2014
ELAPSED TIME 00:00:02
CPU TIME 00:00:00
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
哪位大神能帮看下
NOTE # 1929
NOTE # 1847
FEM model file :
FORCE Sets : 1
SPC Sets : 1
PSHELL Cards : 2
MAT1 Cards : 1
Response Summary :
1 2 1
Direct Method
ITERATION 0
Subcase Compliance
1 2.463659E+00
Mode No. Bound
ID Label
ITERATION 1
Subcase Compliance
1 4.909980E+00
Mode No. Bound
ID Label
ITERATION 2
Subcase Compliance
1 4.909980E+00
Mode No. Bound
ID Label
CPU TIME 00:00:00
哪位大神能帮看下
变量的原始值是2.5,下限是1,上限你设置的也是2.5,是不是要把该上限调整的大一点,>2.5
因为在优化的过程中,并不是没一个变量值都变小的,即使你要求体积或是质量最小,也是有的增大有的减小……
