ABAQUS提交作业后出现如下错误,请求大神指点
浏览:80159
提交作业后,数据检查出现如下错误:
DEGREE OF FREEDOM 11 AND AT LEAST ONE OF DEGREES OF FREEDOM 1 THRU 6 MUST BE ACTIVE IN THE MODEL FOR *DYNAMIC TEMP-DISP. CHECK THE PROCEDURE AND ELEMENT TYPES USED IN THIS MODEL.
Job 12-2: Analysis Input File Processor aborted due to errors.
Error in job 12-2: Analysis Input File Processor exited with an error.
Job 12-2 aborted due to errors.
请教各位大神,不知道哪儿错了。在相互作用里也有设置刚体约束。
