哪位大神帮我把这段ansys焊接后面的循环语句解释一下
浏览:155566
/prep7
rect,0/1000,3/1000,0/1000,0.01/1000
rect,3/1000,10/1000,0/1000,0.01/1000
rect,0/1000,3/1000,0.01/1000,0.02/1000
rect,20/1000,3/1000,0.01/1000,0.02/1000
rect,0/1000,3/1000,1.52/1000,0.02/1000
rect,20/1000,3/1000,1.52/1000,0.02/1000
rect,0/1000,3/1000,1.52/1000,1.53/1000
rect,20/1000,3/1000,1.52/1000,1.53/1000
rect,6/1000,8/1000,8.94/1000,22.94/1000
k,100,0/1000,8.94/1000
k,101,6.9/1000,4.94/1000
aglue,all
lstr,28,100
lstr,100,33
larc,27,34,101
al,5,7,8,33,27
aglue,all
save
f=3500
r_znzn=1.355e-5
r_zncu=4.967e-6
et,1,plane67
keyopt,1,3,1
mp,rsvx,3,2.64e-8
mp,kxx,3,390
mp,c,3,39.8
mp,dens,3,8900
mptemp,1,20,200,400,600,800,1300
mpdata,rsvx,1,1,0.142e-6,0.262e-6,0.458e-6,0.734e-6,1.081e-6,1.220e-6
mptemp,1,50,150,300,650,700,750
mpdata,c,1,1,481,523,569,858,1139,960
mptemp,1,0,200,600,800,1000,1200
mpdata,kxx,1,1,65.3,54.9,45.2,36.4,28.5,27.6,29.7
mp,dens,1,7800
mp,c,2,390
mp,dens,2,7133
mp,kxx,2,270
mp,rsvx,2,4.7e-8
mp,c,4,390
mp,dens,4,7133
mp,kxx,4,270
mptemp,1,21,204,426
mpdata,rsvx,4,1,r_znzn+4.7e-8,r_znzn*0.95+4.7e-8,r_znzn*0.9+4.7e-8
mp,c,5,390
mp,dens,5,7133
mptemp,1,21,204,426
mp,kxx,5,270
mptemp,1,21,204,426
mpdata,rsvx,5,1,r_zncu+4.7e-8,r_zncu*0.95+4.7e-8,r_zncu*0.9+4.7e-8
asel,s,,,2,9,7
aatt,3
alls
asel,s,,,13
aatt,5
alls
asel,s,,,15
aatt,2
alls
asel,s,,,12,14,2
aatt,1
alls
asel,s,,,1
asel,a,,,10,11
asel,a,,,16
aatt,4
alls
lsel,s,,,2,6,2
lsel,a,,,14
lsel,a,,,39,40
lsel,a,,,43,44
lsel,a,,,48
lesize,all,,,1
alls
lsel,s,,,33,35,2
lesize,all,,,
alls
lsel,s,,,34,36,2
lesize,all,,,
alls
lsel,s,,,41,42
lsel,a,,,46
lesize,all,,,
alls
lesize,5,,,20,10
lesize,8,,,40,10
lsel,s,,,1,3,2
lsel,a,,,7,11,4
lsel,a,,,19,27,8
lesize,all,,,
alls
lsel,s,,,47,49,2
lesize,all,
alls
lsel,s,,,37,38
lsel,a,,,45,50,5
lesize,all,
alls
amesh,all
lsel,s,,,35
nsll,s,1
cp,2,volt,all
/solu
lsel,s,,,1
dl,all,blank,volt,0
alls
lsel,s,,,7,36,29
sfl,all,conv,3800
alls
lsel,s,,,8,34,26
lsel,a,,,49
sfl,all,conv,25
alls
fk,35,amps,10000
antype,4
kbc,1
autots,on
outress,all,all
nlgeom,1
sstif,1
nropt,full, ,on
eqslv, , ,0,
precision,0
msave,0
toffst,0,
physics,write,thermal
physics,clear
finish
/prep7
etchg,tts
mp,ex,1,0.207e9
mp,prxy,1,0.275
mp,dens,1,7800
mp,ex,2,0.1e9
mp,prxy,2,0.27
mp,dens,2,7133
mptemp,3,20,100,150,250,300,400,500,600,700
mpdata,ex,3,1,0.115e9,0.11e9,0.106e9,0.102e9,0.101e9,0.097e9,0.09e9,0.081e9,0.075e9
mpdata,prxy,3,1,0.35,0.35,0.35,0.36,0.37,0.37,0.38,0.38,0.39
mp,dens,3,8900
mp,ex,4,0.1e9
mp,prxy,4,0.27
mp,dens,4,7133
mp,ex,5,0.115e9
mp,prxy,5,0.35
mp,dens,5,7800
lsel,s,,,35
nsll,s,1
cp,3,uy,all
alls
lsel,s,,,7
nsll,s,1
cp,4,uy,all
alls
/solu
lsel,s,,,4,5
lsel,a,,,40,44,2
lsel,a,,,36
dl,all,,ux
alls
lsel,s,,,1
lsel,a,,,37
dl,all,,uy
alls
fk, ,fy,
antype,4
kbc,1
autots,on
outress,all,all
physics,write,struct
/solu
physics,read,thermal
ic,all,temp,25
time,0.02
deltim,0.005
solve
*do,a,1,19
*get,elemno,node,,count
*dim,elemtemp,,elemno
*do,aa,1,elemno
*get,elemtemp(aa),node,aa,temp
*enddo
physics,read,struct
/solu
ldread,temp,,, , ,' ','rst',' '
time,0.02
deltim,0.001
solve
/solu
*dim,kill,,50
mm=1
*do,i, ,
*do,j,1,4
*get,nodeno,elem,i,node,j
*get,nodesy,node,nodeno,s,y
*if,nodesy,gt,0,then
kill(mm)=i
*endif
*enddo
*if,kill(mm),ne,0,then
mm=mm+1
*endif
*enddo
*do,aa,1,elemno
ic,aa,temp,elemtemp(aa)
*enddo
/solu
*do,ii,1,50
*if,kill(ii),ne,0,then
ekill,kill(ii)
*endif
*enddo
time,0.02
deltim,0.005
solve
*do,jj,1,50
*if,kill(jj),ne,0,then
ealive,kill(jj)
*endif
*enddo
*enddo
