求ANSYS大神解释
浏览:1206
在ANSYS运行下面命令时,出现警告:
*** WARNING ***                         CP =       1.747   TIME= 19:18:28
 No data points are saved during this storage step.
 *** WARNING ***                         CP =       1.778   TIME= 19:18:28
 No data stored for operations.  The VGET command is ignored.
请问怎么修改命令流啊?万分感谢!!!万分感谢!!!万分感谢!!!
命令流如下:
/POST26
ALLSEL
c=740000
d=32
*DIM,qufudu,ARRAY,qufu,2
*DO,i,1,qufu
  *set,sigm1,-ArrS1(i)
  *set,sigm3,-ArrS3(i)
  mengwei=(abs(sigm1-sigm3))/(2*c*cos(d/180*3.1415926)+(abs(sigm1+sigm3))*sin(d/180*3.1415926))
  qufudu(i,1)=qufu_1(i)
  VGET,qufudu(i,2),mengwei,TEMP,
  RESET
*ENDDO
