求大神:Abaqus/Explicit Analysis exited with an error - Please see the status file for ...
浏览:2217
The job input file "Steady_cutting.inp" has been submitted for analysis.
Job Steady_cutting: Analysis Input File Processor completed successfully.
Job Steady_cutting completed successfully.
Error in job Steady_cutting: Abaqus/Explicit Analysis exited with an error - Please see the status file for possible error messages if the file exists.
Job Steady_cutting aborted due to errors.
作业输入文件“steady_cutting。InP”已提交分析。 工作steady_cutting:分析输入文件处理器成功完成。 工作steady_cutting成功完成。 作业输入文件“steady_cutting。InP”已提交分析。 工作steady_cutting:分析输入文件处理器成功完成。 在工作steady_cutting错误:ABAQUS/Explicit分析存在一个错误-请如果文件存在,看是否有错误信息状态文件。 工作steady_cutting中止由于错误。
