cfd大神帮帮忙啊/(ㄒoㄒ)/~~。。。自己设计的动车外形,正在画网格,打算分析一下,结果就是生成不了边界层网格,救命啊/(ㄒoㄒ)/~~..下面是报错:
浏览:2046 回答:2
整体缩小了一千倍,宽3mm,高4mm,边界层网格0.05mm
求助!!!大神们帮帮忙。。。
报错
No inflation source shells. Can't extrude prisms!
no valid inflation sources.
prism finished
Application is finished.
Error: prism didn't create prism.uns
生成的日志是这么写的:
ANSYS ICEM CFD Prism 16.0 compiled on 12/3/2014 at 3:01 p.m.
running on Windows (64 bit version)
(c) Copyright 1993 - 2014 Ansys Inc.
process PC-20160316IUCY 8884
reading surface model...
reading mesh file...
sizeof mesh_element 24
sizeof element 40
sizeof base_prism 144
sizeof of one prism 152 bytes
sizeof of one tet 176 bytes
max_prism_angle reset to 174.261 because the min_prism_quality is 0.01
WARNING: prism height 0.032 set on surface F_107 overrides
global height 0.002 and part CAR height 0.032
WARNING: prism height 0.032 set on surface F_322 overrides
WARNING: prism height 0.032 set on surface F_526 overrides
WARNING: prism height 0.032 set on surface F_636 overrides
WARNING: prism height 0.032 set on surface F_707 overrides
WARNING: prism height 0.032 set on surface F_786 overrides
WARNING: prism height 0.032 set on surface F_867 overrides
WARNING: prism height 0.032 set on surface F_946 overrides
WARNING: prism height 0.032 set on surface F_1020 overrides
WARNING: prism height 0.032 set on surface F_1143 overrides
……(省略掉了)
done smoothing
marking shells
prism finished
stevezheng
用什么软件做的网格,六面体还是四面体单元?
2016年4月14日
奈more
@仿真小刘
2016年4月5日
