求cfd大神给分析一下错误啊/(ㄒoㄒ)/~~ 边界层从第六层开始质量开始变差
浏览:1251
 边界层从第六层开始质量开始变差
extruding prism layer 6
first_t 16%
first_t 33%
first_t 50%
first_t 66%
1 additional vertices were made degenerated:
  A complete inflation layer in the hexa part of a hybrid mesh might be degenerated!
first_t 83%
returning with first_t == 0.551317
0 flat tetrahedra created between layers
0 pointy tetrahedra created between layers
24 node columns stopped during extrusion because prism couldn't retriangulate
1031 node columns stopped during extrusion because of collisions
worst prism quality: 0.301442
worst pyramid quality: 0.428309
worst tet quality: 0.113998
no orientation errors
writing out prism layer 6
done
initializing directions from levelset norm
155499 prism_nodes
smoothing marching directions
152412 prism_nodes
iteration: 1 worst quality 0.0528648
iteration: 2 worst quality 0.0777117
iteration: 3 worst quality 0.0881835
iteration: 4 worst quality 0.0881843
iteration: 5 worst quality 0.0881933
iteration: 6 worst quality 0.0881936
iteration: 7 worst quality 0.0881929
iteration: 8 worst quality 0.088193
iteration: 9 worst quality 0.088193
iteration: 10 worst quality 0.088193
iteration: 11 worst quality 0.088193
iteration: 12 worst quality 0.088193
final iteration: worst extruded element quality 0.088193
completed smoothing
extruding prism layer 7
first_t 16%
first_t 33%
first_t 50%
first_t 66%
2 additional vertices were made degenerated:
