有人帮看一下为什么我的分析文件做不了优化不
浏览:1252 回答:1
*SET,L1,200
*SET,L2,40
*SET,H1,10
*SET,H2,10
*SET,H3,30
*SET,B1,20
*SET,B2,80
*SET,R1,20
*SET,R2,6
*SET,R3,15
/PREP7
ET,1,SOLID187
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.06E5
MPDATA,PRXY,1,,0.3
CYL4,0,0,20, , , ,10
CYL4,0,0,20, ,6, ,10
BLOCK,17.2,217.2,-10,10,0,10,
BLOCK,17.2,267.2,-10,10,0,10,
BLOCK,97.2,137.2,-60,20,-10,20,
VSBV,       5,       4
VSBV,       3,       1
BLOCK,0,-20,-20,20,0,10,
VSBV,       2,       1
KWPAVE,      45
CSYS,4
CYL4,20,25,15, , , ,-40
VSBV,       6,       1
KWPAVE,      18
FLST,3,3,6,ORDE,2
FITEM,3,2
FITEM,3,-4
VSYMM,X,P51X, , , ,0,0
FLST,2,2,6,ORDE,2
FITEM,2,5
FITEM,2,-6
VGLUE,P51X
FLST,2,2,6,ORDE,2
FITEM,2,3
FITEM,2,-4
VGLUE,P51X
SMRT,6
SMRT,5
SMRT,4
SMRT,3
SMRT,2
MSHAPE,1,3D
MSHKEY,0
FLST,5,6,6,ORDE,4
FITEM,5,1
FITEM,5,-2
FITEM,5,5
FITEM,5,-8
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.2
MAT,1
R,3
REAL,3
ET,2,170
ET,3,174
KEYOPT,3,9,0
KEYOPT,3,10,2
R,3,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,12
ASEL,A,,,49
CM,_TARGET,AREA
TYPE,2
NSLA,S,1
ESLN,S,0
ESLL,U
ESEL,U,ENAME,,188,189
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,58
CM,_CONTACT,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
CMDEL,_TARGET
CMDEL,_CONTACT
CWZDELE,3,1,''
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.2
MAT,1
R,4
REAL,4
ET,4,170
ET,5,174
KEYOPT,5,9,0
KEYOPT,5,10,2
R,4,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,12
CM,_TARGET,AREA
TYPE,4
NSLA,S,1
ESLN,S,0
ESLL,U
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,58
CM,_CONTACT,AREA
TYPE,5
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,4
ESEL,A,TYPE,,5
ESEL,R,REAL,,4
ESEL,ALL
ESEL,S,TYPE,,4
ESEL,A,TYPE,,5
ESEL,R,REAL,,4
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.2
MAT,1
R,5
REAL,5
ET,6,170
ET,7,174
KEYOPT,7,9,0
KEYOPT,7,10,2
R,5,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,24
CM,_TARGET,AREA
TYPE,6
NSLA,S,1
ESLN,S,0
ESLL,U
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,57
CM,_CONTACT,AREA
TYPE,7
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,6
ESEL,A,TYPE,,7
ESEL,R,REAL,,5
ESEL,ALL
ESEL,S,TYPE,,6
ESEL,A,TYPE,,7
ESEL,R,REAL,,5
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.2
MAT,1
R,6
REAL,6
ET,8,170
ET,9,174
KEYOPT,9,9,0
KEYOPT,9,10,2
R,6,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,30
CM,_TARGET,AREA
TYPE,8
NSLA,S,1
ESLN,S,0
ESLL,U
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,47
CM,_CONTACT,AREA
TYPE,9
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,8
ESEL,A,TYPE,,9
ESEL,R,REAL,,6
ESEL,ALL
ESEL,S,TYPE,,8
ESEL,A,TYPE,,9
ESEL,R,REAL,,6
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.2
MAT,1
R,7
REAL,7
ET,10,170
ET,11,174
KEYOPT,11,9,0
KEYOPT,11,10,2
R,7,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,29
CM,_TARGET,AREA
TYPE,10
NSLA,S,1
ESLN,S,0
ESLL,U
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,46
CM,_CONTACT,AREA
TYPE,11
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,10
ESEL,A,TYPE,,11
ESEL,R,REAL,,7
ESEL,ALL
ESEL,S,TYPE,,10
ESEL,A,TYPE,,11
ESEL,R,REAL,,7
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
CMDEL,_TARGET
CMDEL,_CONTACT
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
MP,MU,1,0.2
MAT,1
R,8
REAL,8
ET,12,170
ET,13,174
KEYOPT,13,9,0
KEYOPT,13,10,2
R,8,
RMORE,
RMORE,,0
RMORE,0
ASEL,S,,,28
ASEL,A,,,35
CM,_TARGET,AREA
TYPE,12
NSLA,S,1
ESLN,S,0
ESLL,U
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
ASEL,S,,,40
ASEL,A,,,43
CM,_CONTACT,AREA
TYPE,13
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,12
ESEL,A,TYPE,,13
ESEL,R,REAL,,8
ESEL,ALL
ESEL,S,TYPE,,12
ESEL,A,TYPE,,13
ESEL,R,REAL,,8
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
CMDEL,_TARGET
CMDEL,_CONTACT
FINISH
/SOL
FLST,2,4,5,ORDE,4
FITEM,2,1
FITEM,2,3
FITEM,2,5
FITEM,2,-6
/GO
DA,P51X,ALL,
FLST,5,4,4,ORDE,4
FITEM,5,23
FITEM,5,26
FITEM,5,103
FITEM,5,106
LSEL,S, , ,P51X
NSLL,S,1
FLST,2,58,1,ORDE,14
FITEM,2,18
FITEM,2,-19
FITEM,2,21
FITEM,2,68
FITEM,2,70
FITEM,2,72
FITEM,2,324
FITEM,2,-336
FITEM,2,365
FITEM,2,-377
FITEM,2,2049
FITEM,2,-2061
FITEM,2,2082
FITEM,2,-2094
/GO
F,P51X,FZ,-1.5
ALLSEL,ALL
SOLVE
FINISH
AVPRIN,0, ,
ETABLE,EVOL,VOLU,
SSUM
ETABLE,EVOL,VOLU,
SSUM
*GET,ETOT,SSUM, ,ITEM,EVOL
*SET,RHO,7.8E-3
*SET,WT,RHO*ETOT
NSORT,U,Z,0,1, ,SELECT
*GET,UZ,SORT,,MAX
*SET,DZ,ABS(UZ)
奈more
@张磊
2016年4月11日
