- 技术邻 >
- CAE仿真 >
- HyperWorks
Hypermesh tetramesh 问题: "1 surfs failed and saved "
浏览:2484 回答:6
3d - tetramesh, 有问题出现提示: 'shell elem region incomplete' 然后是: 1 surfs failed and saved , 解决那个有问题的 surface, 重新tetramesh , 结果还是一样, 又会出现 新的 surface, 提示: 1 surfs failed and saved . 怎么解决?
