fluent 多相流计算设置outflow与pressure outlet提示不能计算?
浏览:3371 回答:5
做fluent多相流计算的时候(速度入口设置在另一个地方),顶部设置了pressure outlet,底部设置了outflow,结果fluent出现了下面提示:
Warning: Both outflow and pressure boundaries are present in the domain. This is an incompatibility and solution cannot proceed until this is fixed.
这个应该怎么解决啊
