CFX调用WB进行remeshing
浏览:1359 回答:1
本人采用CFX的user define动网格的方式计算一个管的流场域,内管壁采用rigid body,并以120[rev/min]旋转。模型如下图所示。
参照网上各位大神传授的CFX动网格方法,我进行了下面的设置:
但是结算到开始remeshing的时候,就出错了,错误信息如下所示:
 |                             Remeshing                              |
 Remesh Object: Remesh 1
   Activated by condition: Interrupt Condition 1
   Executing remesh command:
      "D:\Program Files\ANSYS
      Inc\v160\Framework\bin\Win64\runwb2.bat" -B -R
      F:\movemesh\remesh.wbjn
 CFX Solver Results generated before remeshing have been written to:
   F:\movemesh\Unnamed_001\56_oldmesh.res
 Text output generated during remeshing has been written to:
   F:\movemesh\Unnamed_001\56_remesh.out
 |                An error has occurred in cfx5solve:                 |
 | ANSYS CFX Solver Input File does not exist                         |
 | The following user files have been saved in the directory          |
 | F:\movemesh\Unnamed_001:                                           |
 | cfxpre_engine_error.log, 56_remesh.out, 56_oldmesh.res             |
This run of the ANSYS CFX Solver has finished.
我更改过单位什么的,但是还是提示ANSYS CFX Solver Input File does not exist ,运行完脚本remesh。wbjn文件后,F:\movemesh\movemesh6_files\dp0\global\MECH\SYS.mshdb文件是存在的。不知道为什么说不能导入mesh以及ANSYS CFX Solver Input File does not exist。
这个问题纠结我快一个月了,继续解决,前来请教各位老师,非常感谢,非常感谢,非常感谢
奈more
@寒风F @steve_zheng
2016年4月25日
