abaqus出错,大神帮看下。
浏览:1576 回答:1
小弟新手,用hypermesh做前处理,然后导入abaqus求解,是静力学问题。然后就报好多这样的错:
No bulk modulus is defined for acoustic element 1539867 instance part-1-1. All acoustic elements must have nonzero bulk modulus defined using *material and *acoustic medium.
Initialization of acoustic element material point data for element 401 has failed because no bulk modulus exists for thiselement.
在abaqus里面重新设置材料还是这样。求大神帮帮忙。
