顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ANSYS APDL 进行不平衡激励启动过程的瞬态分析时,出现下列警告是哪里出问题了?
浏览: 2205
警告:① The MINREF field of the CNVTOL command has been assigned a default value of 1.0 for convergence on F.  Check results carefully.
       ② BEAM189 will generate a gyroscopic damping matrix contribution(stationary frame ON on the CORIOLIS command) in a dynamic analysis.The element matrix will be non-symmetric.
       ③ The gyroscopic damping matrix (stationary frame ON in the CORIOLIS command) is based on small deflection theory.  The large deflection effect (NLGEOM,ON) needs to be used with caution.
APDL语言如下:
FINISH
/CLEAR
/CONFIG,NRES,10000
/PREP7
L1=0.01
L2=0.112
L3=0.0162
L4=0.034
L5=0.041
L6=0.01
L0=L3+L4+L5
D=0.01
R1=0.051
R2=0.0208
R3=0.0295
T1=0.0187
T2=0.015
T3=0.0187
MUNB1=1E-4
MUNB2=6E-5
MUNB3=2E-5
MUNBR1=0.01
MUNBR2=0.01
MUNBR3=0.01
ET,1,BEAM189
ET,2,COMBI214,,1
MP,EX,1,2.19E11
MP,PRXY,1,0.3
MP,DENS,1,7830
SECTYPE,1,BEAM,CSOLID
SECDATA,R1,16,4
SECTYPE,2,BEAM,CSOLID
SECDATA,R2,16,4
SECTYPE,3,BEAM,CSOLID
SECDATA,R3,16,4
SECTYPE,4,BEAM,CSOLID
SECDATA,D/2
R,1,2.4E8,1.8E8,3E7,3E7,2.15E5,7.5E4
RMORE,6E4,6E4
R,2,8.2E7,7.4E7,-2E6,-2E6,2.45E5,1.50E5
RMORE,5.5E4,5.5E4
K,1
K,2,,,L1-T1/2
K,3,,,L1
K,4,,,L1+T1/2
K,5,,,L1+L2-T2/2
K,6,,,L1+L2
K,7,,,L1+L2+T2/2
K,8,,,L1+L2+L0-T3/2
K,9,,,L1+L2+L0
K,10,,,L1+L2+L0+T3/2
K,11,,,L1+L2+L0+L6
K,12,,R1
K,13,,R2
K,14,,R3
L,1,2
L,2,3
L,3,4
L,4,5
L,5,6
L,6,7
L,7,8
L,8,9
L,9,10
L,10,11
LSEL,S,,,1,10,3
LATT,1,,1,,,14,4
LSEL,S,,,2,3
LATT,1,,1,,,14,1
LSEL,S,,,5,6
LATT,1,,1,,,14,2
LSEL,S,,,8,9
LATT,1,,1,,,14,3
LSEL,ALL
ESIZE,D/2
LMESH,ALL
N1=NODE(0,0,L1+L2+L3)
N2=NODE(0,0,L1+L2+L3+L4)
N,1000,,0.1,NZ(N1)
N,2000,,0.1,NZ(N2)
TYPE,2
REAL,1
MAT,1
E,N1,1000
E,N2,2000
D,1000,ALL
D,2000,ALL
D,N1,,,UZ,,,ROTZ
D,N2,ROTZ
FINISH
PI=ACOS(-1)
SPIN=4000*PI/30
DT=5E-4
TEND=3
SPINSLO=SPIN/TEND
NPOINT1=NINT(TEND/DT)+1
NPOINT2=NPOINT1+NINT(1/DT)+1
*DIM,FXU1,TABLE,NPOINT2,,,TIME
*DIM,FYU1,TABLE,NPOINT2,,,TIME
*VFILL,FXU1(1,0),RAMP,0,DT
*VFILL,FYU1(1,0),RAMP,0,DT
*DO,I,1,NPOINT1
TI=(I-1)*DT
SPINTI=SPINSLO*TI
SPINTI2=SPINTI**2
ROTTI=SPINSLO*TI**2/2
SINR=SIN(ROTTI)
COSR=COS(ROTTI)
FXU1(I,1)=MUNB1*MUNBR1*(SPINTI2*COSR-SPINSLO*SINR)
FYU1(I,1)=MUNB1*MUNBR1*(SPINTI2*SINR+SPINSLO*COSR)
*ENDDO
*DO,I,NPOINT1,NPOINT2
TI=(I-1)*DT
SPIN2=SPIN**2
ROTTI=SPINSLO*TEND**2/2+SPIN*(TI-TEND)
SINR=SIN(ROTTI)
COSR=COS(ROTTI)
FXU1(I,1)=MUNB1*MUNBR1*SPIN2*COSR
FYU1(I,1)=MUNB1*MUNBR1*SPIN2*SINR
*ENDDO
*DIM,FXU2,TABLE,NPOINT2,,,TIME
*DIM,FYU2,TABLE,NPOINT2,,,TIME
*VFILL,FXU2(1,0),RAMP,0,DT
*VFILL,FYU2(1,0),RAMP,0,DT
*DO,I,1,NPOINT1
TI=(I-1)*DT
SPINTI=SPINSLO*TI
SPINTI2=SPINTI**2
SINR=SIN(ROTTI)
COSR=COS(ROTTI)
FXU2(I,1)=MUNB2*MUNBR2*(SPINTI2*COSR-SPINSLO*SINR)
FYU2(I,1)=MUNB2*MUNBR2*(SPINTI2*SINR+SPINSLO*COSR)
*ENDDO
TI=(I-1)*DT
SPIN2=SPIN**2
SINR=SIN(ROTTI)
COSR=COS(ROTTI)
FXU2(I,1)=MUNB2*MUNBR2*SPIN2*COSR
FYU2(I,1)=MUNB2*MUNBR2*SPIN2*SINR
*ENDDO
*DIM,FXU3,TABLE,NPOINT2,,,TIME
*DIM,FYU3,TABLE,NPOINT2,,,TIME
*VFILL,FXU3(1,0),RAMP,0,DT
*VFILL,FYU3(1,0),RAMP,0,DT
*DO,I,1,NPOINT1
TI=(I-1)*DT
SPINTI=SPINSLO*TI
SPINTI2=SPINTI**2
SINR=SIN(ROTTI)
COSR=COS(ROTTI)
FXU3(I,1)=MUNB3*MUNBR3*(SPINTI2*COSR-SPINSLO*SINR)
FYU3(I,1)=MUNB3*MUNBR3*(SPINTI2*SINR+SPINSLO*COSR)
*ENDDO
TI=(I-1)*DT
SPIN2=SPIN**2
SINR=SIN(ROTTI)
COSR=COS(ROTTI)
FXU3(I,1)=MUNB3*MUNBR3*SPIN2*COSR
FYU3(I,1)=MUNB3*MUNBR3*SPIN2*SINR
*ENDDO
/SOLU
ANTYPE,TRANSIENT
NLGEOM,ON
CORIOLIS,ON,,,ON
OUTRES,ALL,ALL
AUTOTS,ON
CNVTOL,F,,0.005
DMPRAT,0.005
KBC,0
TIME,1.5
DELTIM,DT,0.1*DT,10*DT
OMEGA,,,SPINSLO*1.5
N3=NODE(0,0,L1)
F,N3,FX,%FXU1%
F,N3,FY,%FYU1%
N4=NODE(0,0,L1+L2)
F,N4,FX,%FXU2%
F,N4,FY,%FYU2%
N5=NODE(0,0,L1+L2+L0)
F,N5,FX,%FXU3%
F,N5,FY,%FYU3%
SOLVE
TIME,TEND
DELTIM,DT,0.1*DT,2*DT
OMEGA,,,SPIN
SOLVE
TIME,TEND+1
SOLVE
FINISH
/POST26
NSOL,2,N3,U,X
PROD,3,2,2
NSOL,4,N3,U,Y
PROD,5,4,4
ADD,6,3,5
SQRT,7,6
NSOL,2,N4,U,X
PROD,3,2,2
NSOL,4,N4,U,Y
PROD,5,4,4
ADD,6,3,5
SQRT,8,6
NSOL,2,N5,U,X
PROD,3,2,2
NSOL,4,N5,U,Y
PROD,5,4,4
ADD,6,3,5
SQRT,9,6
PLVAR,7,8,9
XVAR,2
PLVAR,4
*GET,TMAX7,VARI,7,EXTREM,TMAX
/POST1
/VIEW,1,1,1,1
/ESHAPE,1
SET,,,,,TMAX7
PLNSOL,U,SUM
PLNSOL,S,X
@htbbzzg
ANSYS CAE 结构CAE
全部回答 (0)
相似问题
查看全部
  • 弧长法计算,在ansys14.5上正常运行的命令流,为什么到2021 R2 高版本上就算不了? 2个回答
    一个弹性拱在自重下的变形计算,很简单的模型,在ansys14.5上用弧长法正常计算,换到2021R2上就算不了了,2019版也试了,也是不收敛。不知道是为什么,请大佬指点。附模型命令流如下: fini /clear /prep7 ! 拱轴参数 L = 7500 H = 1500 L_num= 60 len = L/L_num MP, DENS, 1, 2.6e-6 mp,ex,1,34500 mp
  • 进行优化分析时出错,不知道问题出在哪 暂无回答
    提示:modification of an optimization variable has forced a partial clear of your optimization on data.Design sets and global optimization settings are unchanged,but all other data has been initialized.
  • ansys线—线接触和线—面接触的间隙问题怎么处理? 1个回答
    你好,我用线-面接触和线-线接触分别模拟主缆钢丝与鞍槽接触和主缆钢丝与钢丝之间相互接触行为,钢丝与钢丝、鞍槽之间都有一定的间隙,钢丝之间存在5.25mm(钢丝直径)间隙,钢丝与鞍槽侧壁存在2.625mm(钢丝半径)间隙,因为钢丝与鞍槽的曲率半径不同,所以钢丝与鞍槽底面的间隙不清楚,具体的我把命令流和错误提示附上各位帮看一下。 命令流如下: finish$/clear$/prep7 !1.几何模型
推荐阅读
ABAQUS中级教程合集--搞定滞回曲线
1点 1点
¥299
Apex For Aerospace Applications Introduction
MSC Apex
免费
公路钢筋混凝土及预应力混凝土桥涵设计规范解决方案
敦樸DUNPU 敦樸DUNPU
免费
慧加新规范解决方案详解之大跨连续弯梁桥精细化分析(7DOF)
敦樸DUNPU 敦樸DUNPU
免费
混合弯头的流体流动与传热
混合弯头的流体流动与传热
CFD流 CFD流
免费
Abaqus子程序安装教程 Abaqus6.14.2+VS2013+IVF2013(附带安装包)
二十 二十
免费
北京华盛扬科技 北京华盛扬科技
¥9.9
Msc Apex For Aerospace Applications Idealization a
MSC Apex
免费
超大规模芯片电源完整性签核平台RedHawk-SC应用分享
Ansys中国 Ansys中国
免费
ALTAIR ALTAIR
免费
结构仿真职业规划与学习路线
结构仿真职业规划与学习路线
技术邻直播 技术邻直播
免费
人工智能工程应用实例: 发动机排放数据学习及预测
IDAJ中国 IDAJ中国
¥99
Altair二次开发答疑&典型案例解读
Altair二次开发答疑&典型案例解读
ALTAIR ALTAIR
¥10
MATLAB/ADAMS求解动力学
MATLAB/ADAMS求解动力学
伟_sss 伟_sss
¥25
基于OptiSturct的线性静力学分析和尺寸优化
Leon_sun Leon_sun
¥10
AQWA软件企业培训(3)  通过ANSYS-APDL建立半潜平台混合模型及混合模型的拖曳力线性化
Nutshell Nutshell
¥30
TurboTides TurboTides
免费
UG编程零基础入门到精通以及优化刀路教程
UG编程 UG编程
免费
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
十分钟快速进行电子产品结构设计方案评估
十分钟快速进行电子产品结构设计方案评估
技术邻直播 技术邻直播
免费
