浏览:629 回答:1
@陈超然 您好 请问在hyperworks优化计算中出现这个问题应该怎样修改,谢谢! There were 18 error messages during input processing. The first message is repeated below: *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 191319 component = 1
陈超然
你是否重复定义了rbe2单元
2016年5月27日
