hypermesh求解时出现错误radioss buikdate在线等,求大神解释
浏览:2383 回答:2
 *** OptiStruct defaults set from:
   install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg.
 NOTE # 9199
 MSGLMT=BRIEF is active, following messages will be suppressed:
 741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010
 Use MSGLMT=STRICT (e.g. in config file) to turn back full printing.
 *** INFORMATION #  743
 The total number of rigid elements, whose rotational dependent d.o.f.
 are removed because there is no need to constrain those d.o.f., is        36
 *** ERROR # 173 ***
 A dependent d.o.f. defined more than once in rigid element entry.
    GRID ID =   248928
  component =        1
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        2
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        3
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        4
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        5
 *** ERROR # 173 ***
    GRID ID =   248928
  component =        6
OPTIMIZATION FILE AND PARAMETER INFORMATION :
  FEM model file               : E:/assemble five 119(5).fem
  Output files prefix          : E:/assemble five 119(5)
  Model read from files:
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :    108699
  Total # of Elements                  :    116522
  Total # of Rigid Elements            :      2354
  Total # of Rigid Element Constraints :     14124
  Total # of Degrees of Freedom        :    642531
  Total # of Non-zero Stiffness Terms  :  17583135
  Element Type Information
   CTETRA   Elements   :     8545
   CPYRA    Elements   :     1381
   CQUAD4   Elements   :   105550
   CTRIA3   Elements   :     1046
  Load and Boundary Information
   FORCE Sets        :         1
   SPC   Sets        :         1
  Material and Property Information
   PSOLID Cards      :         1
   PSHELL Cards      :         1
   MAT1   Cards      :         1
 ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
 Current Memory (RAM)                                    :     204 MB
 Estimated Minimum Memory (RAM) for the check run        :     207 MB
 This error occurs in module "prpdrv".
RESOURCE USAGE INFORMATION
 MAXIMUM MEMORY USED                                       204 MB
 MAXIMUM DISK SPACE USED                                     1 MB
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Sun May 22 22:45:41 2016
 EXECUTION COMPLETED                       Sun May 22 22:45:44 2016
 ELAPSED TIME                                         00:00:02
 CPU TIME                                             00:00:02
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 http://www.altairhyperworks.com/tips.aspx
 There were 6 error messages during input processing.
  The first message is repeated below:
  *** ERROR # 173 ***
     GRID ID =   248928
   component =        1
haidaidaihai
刚性单元的节点不能直接施加自由度
2016年8月19日
奈more
@智创仿真
2016年5月23日
