Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
浏览: 1687 回答: 3
@智创仿真 *** OptiStruct defaults set from: install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg. NOTE # 9199 MSGLMT=BRIEF is active, following messages will be suppressed: 741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010 Use MSGLMT=STRICT (e.g. in config file) to turn back full printing. *** INFORMATION # 743 The total number of rigid elements, whose rotational dependent d.o.f. are removed because there is no need to constrain those d.o.f., is 36 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 1 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 2 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 3 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 4 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 5 *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 6 ************************************************************************ OPTIMIZATION FILE AND PARAMETER INFORMATION : --------------------------------------------- FEM model file : E:/assemble five 119(5).fem Output files prefix : E:/assemble five 119(5) Model read from files: E:/assemble five 119(5).fem ************************************************************************ ************************************************************************ FINITE ELEMENT MODEL DATA INFORMATION : --------------------------------------- Total # of Grids (Structural) : 108699 Total # of Elements : 116522 Total # of Rigid Elements : 2354 Total # of Rigid Element Constraints : 14124 Total # of Degrees of Freedom : 642531 Total # of Non-zero Stiffness Terms : 17583135 Element Type Information ------------------------ CTETRA Elements : 8545 CPYRA Elements : 1381 CQUAD4 Elements : 105550 CTRIA3 Elements : 1046 Load and Boundary Information ----------------------------- FORCE Sets : 1 SPC Sets : 1 Material and Property Information --------------------------------- PSOLID Cards : 1 PSHELL Cards : 1 MAT1 Cards : 1 ************************************************************************ ************************************************************************ ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN ***** Current Memory (RAM) : 204 MB Estimated Minimum Memory (RAM) for the check run : 207 MB ************************************************************************ This error occurs in module "prpdrv". ************************************************************************ RESOURCE USAGE INFORMATION -------------------------- MAXIMUM MEMORY USED 204 MB MAXIMUM DISK SPACE USED 1 MB ************************************************************************ ************************************************************************ COMPUTE TIME INFORMATION ------------------------ EXECUTION STARTED Sun May 22 22:45:41 2016 EXECUTION COMPLETED Sun May 22 22:45:44 2016 ELAPSED TIME 00:00:02 CPU TIME 00:00:02 ************************************************************************ *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED. ***** END OF REPORT ***** For Useful OptiStruct Tips and Tricks, go to the URL: http://www.altairhyperworks.com/tips.aspx ************************************************************************ There were 6 error messages during input processing. The first message is repeated below: *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 248928 component = 1 **************************************************** 这个如何解决啊
全部回答 (2)
陈关宝 2016年5月23日
@智创仿真 ,哈哈哈 你真幽默 另PS一句:错误不是告诉你了吗?GRID ID = 248928 shift+F5,里面by id查找
2016年5月23日
智创仿真 2016年5月23日
你可真直接啊,把所有的信息都贴出来了。rigid单元上约束有问题。
2016年5月23日
相似问题
查看全部
  • hypermesh,radioss bulkdate求解时出现错误 6个回答
  • hypermesh求解时出现错误radioss buikdate在线等,求大神解释 2个回答
  • hyperworks 求助 很急 在线等 6个回答
    hyperworks 进行优化分析时出现错误 提示如下: There were 18 error messages during input processing. The first message is repeated below: *** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element e
推荐阅读
【专题课程】ANSA HEXABLOCK六面体网格划分专题(完结)
Wonderful仿真 Wonderful仿真
¥399
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
abaqus模拟桩(三维)全过程
abaqus模拟桩(三维)全过程
红日当空q3120210076 红日当空q3120210076
¥62
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
TurboTides TurboTides
免费
