妹纸真心提问,望大神看到回答
浏览:2714 回答:5
错误以及警告里边出现这个一般是哪里出了问题啊,怎么解决
DIFFERENTIAL STIFFNESS MATRIX IS COMPLETELY NULL.  THE EIGENPROBLEM CANNOT BE SOLVED.  IN A *BUCKLE ANALYSIS THE MOST LIKELY CAUSE IS THAT A NONZERO LOADING PATTERN WAS NOT SPECIFIED VIA *BOUNDARY, *CLOAD, *DLOAD, ETC,.  SEE Eigenvalue Buckling Prediction IN THE Abaqus/Standard USERS MANUAL
Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.
Slave surface assembly__pickedset23_cns_ is a node-based surface used with surface to surface approach. In order to obtain improved stress accuracy with this approach, an element-based surface should be used instead.
For *tie pair (assembly__pickedset23_cns_-assembly__pickedsurf22), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf25-assembly__pickedsurf24), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
The specified type of interaction cannot be created or resumed in this type of step. Contact pair definition will not written to the ODB.
There are 2 unconnected regions in the model.
李岩
应该是有参考点没有给质量
2016年5月28日
定春不是猫
修正下技术点 帮你@专家
2016年5月23日
评论 3 点赞
