MASS166单元用法
浏览:1318 回答:1
请教一下大仙们,关于mass166单元的用法。在模型中指定节点处生成mass166单元时,里面有个质量单元的材料属性号,那mass质量单元需要设置材料属性?还有就是mass单元需要和他所附属节点间建立什么连接
@周游 @Ileana @蓝牙
蓝牙
mass单元是不需要设置材料。
ansys手册中有明确的描述
节点数:1
自由度:
UX, UY, UZ, VX, VY, VZ, AX, AY, AZ
Note:  For explicit dynamic analyses, V(X, Y, Z) refers to nodal velocity, and A(X, Y, Z) refers to nodal acceleration. Although V(X, Y, Z) and A(X, Y, Z) appear as DOFs, they are not actually physical DOFs. However, these quantities are computed as DOF solutions and stored for postprocessing.
Real Constants
If KEYOPT(1) = 0:
只需输入质量
If KEYOPT(1) = 1:
输入转动惯量
IXX - Moment of inertia (must be > 0),
IXY - Moment of inertia,
IXZ - Moment of inertia,
IYY - Moment of inertia (must be > 0),
IYZ - Moment of inertia,
IZZ - Moment of inertia (must be > 0)
材料属性
None, but you must define realistic dummy material properties to make this element behave correctly. The dummy properties will not be used in any solution.
Surface Loads
None
Body Loads
None
Special Features
All nonlinear features allowed for an explicit dynamic analysis.
KEYOPT(1)
Rotary inertia option:
0 --
3-D mass without rotary inertia (default)
1 --
3-D rotary inertia (no mass)
2016年5月26日
已采纳 评论 点赞
