mesh画网格导入fluent中出现警告 这个怎么处理
浏览:2969 回答:1
auto partitioning mesh by Principal Axes
    Warning: Partition method "Metis" is not allowed for
              autopartitioning for cases with nonconformal
              interfaces before the interfaces are defined
              and intersected, use "Principal Axes" instead.
              You may use the "Metis" partition method
              after the case is read in and the interfaces
              are intersected.
 这个怎么处理
stevezheng
把interface设置一下就行了
2016年7月18日
