ABAQUS问题
浏览:1179 回答:2
error:Too many attempts made for this increment
Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
wanning:Path based tracking is defined in contact pair (assembly_s_surf-9,assembly_part-3-1_m_surf-3). Path based tracking cannot be used with analytical rigid master surfaces, the state based tracking algorithm will be used instead.
Solver problem. Zero pivot when processing D.O.F. 1 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_1_1.
求大神解答
