顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus隐式分析中contact control设置问题以及后处理中输出的strain energy为负值切较大的问题
浏览: 7003 回答: 4
模拟一层预浸料弯曲变形,使用的是S4单元,
contact control设置如下
仿真完成之后creat xy data
ALLSD和ALLSE
其中ALLSD随着时间步数值如下:
0 0
0.000758867 1.5037E-010
0.0443268 6.14717
0.291301 3475.9
0.344406 8131.14
0.700145 17450.8
1 17845.1
ALLSE随着时间步如下
0 -2.20256E+008
0.000758867 -2.20256E+008
0.0443268 -2.20256E+008
0.291301 -2.20192E+008
0.344406 -2.20143E+008
0.700145 -2.20087E+008
1 -2.20084E+008
而动能ALLKE却一直未零!!
abaqus帮助文档里面的说明如下:
 Although the automatically calculated damping coefficient typically provides enough damping to eliminate the rigid body modes without having a major effect on the solution, there is no guarantee that the value is optimal or even suitable. This is particularly true for thin shell models, in which the damping may be too high. Hence, you may have to increase the damping if the convergence behavior is problematic or decrease the damping if it distorts the solution. The first case is obvious, but the latter case requires a postanalysis check. There are several ways to carry out such checks. The simplest method is to consider the ratio between the energy dissipated by viscous damping and a more general energy measure for the model, such as the elastic strain energy. These quantities can be obtained as output variables ALLSD and ALLSE, respectively. More detailed information can be obtained by comparing the contact damping stresses CDSTRESS (with the individual components CDPRESS, CDSHEAR1, and CDSHEAR2) to the true contact stresses CSTRESS (with the individual components CPRESS, CSHEAR1, and CSHEAR2). If the contact damping stresses are too high, you should decrease the damping. The comparison should be made after contact is firmly established; the contact damping stresses will always be relatively high when contact is not yet or only partially established.
大概意思是设置contact control可以有助于收敛,可是结果需要自己来验证,可以用ALLSD与ALLSE的比值来判断结果的准确性,可是我这个ALLSE是负值,虽然绝对值很大。
使用的s4单元,排除了沙漏能造成能量为负的原因
我的问题是我的结果是否可靠呢?帮助文档里面说的对比ALLSE和ALLSD是用的是绝对值来对比吗?
@邹十平 @fhaih @刘瑾 @ssg @邓晓迪 @tytyy @魏岩 @夏嘉延 @撒打算打算 @yzdsd @noncivilized @李呵呵 @君莫 @changyingluanwu @房博士
ABAQUS CAE 结构CAE
全部回答 (3)
阿瓦隆号 2019年5月29日
我从来没检查过这个能量。这个参数在我看来是为了解决初试接触不良,刚体位移而存在的,接触稳定后就没啥意义了。比的话我印象是ALLSD ALLIE
2019年5月29日
评论 点赞 1
微信公众号:FILWTBY 2016年10月6日
ALLIE也是负值,大小和ALLSE一样
2016年10月6日
评论 点赞 1
7long 2017年2月24日
楼主解决了吗?contact control这个误差的评估您是什么经验?谢谢!
2017年2月24日
相似问题
查看全部
  • LS-DYNA关键字中的CONTROL_ENERGY是用来干嘛的啊? 4个回答
    如题,一直不明白CONTROL_ENERGY的具体作用,只知道是能量控制,但是是怎么控制的呢?哪位大神能帮我解释下?不胜感激
  • 请问接触控制 contact control 里的stabilization的误差怎么评估? 9个回答
    因为接触总不收敛,也没有特别的warning.使用stabilization 的确能促进收敛,但这个带来的误差一般怎么评估呢?比较能量或者应力吗?一般比值在个什么范围比较合理呢?谢谢
  • abaqus接触在初始步(initial)加不上去contact control ,怎能加上? 3个回答
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
abaqus模拟桩(三维)全过程
abaqus模拟桩(三维)全过程
红日当空q3120210076 红日当空q3120210076
¥62
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
