瞬态分析--车轮转动时辐条的弯曲应力。结果不收敛怎么办?
浏览:1181 回答:5
车轮转动时,求轴对车轮中心的向下压力导致辐条的弯曲变形的应力。将车轮外圈作为固定的转动副,车轴端部与车轮中心孔绑定约束,
时间步:车轮一圈是0.05s
加载:转速是1200rpm,车轴远端给定一个固定的y方向的力。
求一圈的瞬时应力。
结果错误:The solver engine was unable to converge on a solution for the nonlinear problem as constrained. Please see the Troubleshooting section of the Help System for more information.
