如何在DEFINE_SOURCE(de_sox,c,t,dS,eqn)中查找离散相的质量什么的
浏览:1269 回答:1
real S_g_so2=0.;
real total_mass=0.,mean_mass=0.;
real total_diam=0.,mean_diam=0.;
real total_urel=0.,mean_urel=0.;
real total_p_temp=0.,mean_p_temp=0.;
real Aint=0.;
int i=0;
mu_g=C_MU_T(c,t)+1.e-8;
rho_g=C_R(c,t)+1.e-8;
pg=C_P(c,t)+1.e-8;
real Re,Sc,Sh,k_g_so2,Hso2,D_l_so2,f,k_l_so2,K_G,P_g_so2,mu_g,rho_g,pg,Tp;
/* particle index for looping over all particles */
Particle *pi;
/* loop over all particles in the cell to find their mass and weighted mean velocity and diameter */
real Tp=P_T(pi);/* particle temperature*/
begin_particle_cell_loop(pi,c,t)
total_mass+=pi->state.mass;
total_diam+=pi->state.diam;
total_urel+=urel(pi,c,t);
total_p_temp+=pi->state.temp;
i=i+1;
end_particle_cell_loop(pi,c,t)
我用的begin_particle_cell_loop(pi,c,t)来查找离散相中的质量,加载和load都可以,没有错误,但是一计算初始化就出现四个错误那个提醒,只能重启anysys重新导入,还是出现错误Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
求大神提示怎么修改
技术工
@龙樱@液风@steve_zheng @Big_ocean@CAE小牛
2016年12月22日
