workbench齿轮瞬态动力学分析
浏览:1595 回答:7
错误提示是
The solver engine was unable to converge on a solution for the nonlinear problem as constrained.  Please see the Troubleshooting section of the Help System for more information.
solution information里面的error是
 One or more elements have become highly distorted.  Excessive
 distortion of elements is usually a symptom indicating the need for
 corrective action elsewhere.  Try ramping the load up instead of step
 applying the load (KBC,1).  You may need to improve your mesh to
 obtain elements with better aspect ratios.  Also consider the behavior
 of materials, contact pairs, and/or constraint equations.  If this
 message appears in the first iteration of first substep, be sure to
 run shape checking of elements.
求大神帮助,谢谢
(4)
Treasury-CAE
你这么说我也不能确定对不对,看不到你的图,我这有做好的齿轮啮合的文件,需要的话联系我。
2017年1月3日
Jamesonl
网格变形剧烈。材料模量设置太小了?单位没弄错吧?
2017年1月3日
已采纳 评论 1 点赞
Treasury-CAE
1、网格问题;2边界条件设置问题,仔细检查
2017年1月2日
韩罗峰
一个是检查网格,加密网格。另一个是,检查边界条件,瞬态分析注意受力平衡。
2017年1月2日
