这个abaqus错误信息提示,可视化中没有结果,element set ErrElemMissingSection需要怎么操作才能打开啊?
浏览:2449 回答:2
***ERROR: 4 elements have missing property definitions. The elements have been
identified in element set ErrElemMissingSection.
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
***WARNING: 4 elements have incorrect property definitions. The elements have
been identified in element set WarnElemIncorrectProperty.
***ERROR: SECTION DEFINITIONS ARE MISSING OR INCORRECT FOR THE ELEMENTS
INDICATED ABOVE. FURTHER PROCESSING OF THE INPUT FILE IS NOT
POSSIBLE UNTIL THIS INPUT ERROR IS FIXED.
