浏览:2306 回答:1
ansys预应力模态分析,出现you have performed a pre-stress modal analysis with large deflection effects turned off in the static analysis. for a more accurate te modal solution,we recommend turning on large deflection effects.怎么解决,具体应该怎么做,急求谢谢了
