请问这个错误有没有好的解决办法?
浏览:3268 回答:2
There is not enough memory for the Sparse Matrix solver to proceed.Please increase the virtual memory on your system and/or increase the work space memory and rerun ANSYS. Alternatively, forcing the use of the minimum out-of-core memory mode (BCSOPTION,,MINIMUM) may allow a solution to be achieved without increasing the system memory or decreasing the problem size. The memory currently allocated by ANSYS = 684 MB. The memory allocation attempted = 298 MB. The largest block of ANSYS memory available for the Sparse Matrix solver = 121 MB.
第二种方法,增加虚拟内存:a,右击电脑-》属性;b,见下图,
c,还是不能解决,换硬件,增加内存条,换
