- 技术邻 >
- CAE仿真 >
- HyperWorks ,
- Abaqus
hypermesh和abaqus对接的时候在rigid上加载荷出现的问题?
浏览:1526 回答:7
在hypermesh做前处理,在设置一个rigid的kinmatic——couping多点耦合,如下图所示:
然后在独立点上施加集中力,提交给abaqus求解的时候出现如下错误:
Concentrated load is specified on 2 nodes that are not active. Check loading definitions in the model. The nodes may have been deleted because they were not connected to any elements.
Boundary conditions are specified on 2 nodes that are not active in this. model. The nodes may have been deleted because they were not connected to any elements.
Analysis Input File Processor exited with an error.
这个问题怎么破
