ABAQUS不收敛原因求助?
浏览:1989 回答:1
***WARNING: THE SYSTEM MATRIX HAS 1 NEGATIVE EIGENVALUES.
             EXPLANATIONS ARE SUGGESTED AFTER THE FIRST OCCURRENCE OF THIS MESSAGE.
     ASYNCHRONOUS TRACKING ELEMENT LOOP STARTED
               CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION     1
 AVERAGE FORCE                      1.410E+06   TIME AVG. FORCE       1.410E+06
 LARGEST RESIDUAL FORCE             5.795E+08   AT NODE         51   DOF  2
   INSTANCE: GUANDAO1
 LARGEST INCREMENT OF DISP.         2.439E+04   AT NODE         46   DOF  3
   INSTANCE: GUANDAO1
 LARGEST CORRECTION TO DISP.        2.433E+04   AT NODE         46   DOF  3
   INSTANCE: GUANDAO1
          FORCE     EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
 AVERAGE MOMENT                     9.768E+04   TIME AVG. MOMENT      9.768E+04
 LARGEST RESIDUAL MOMENT            1.994E+07   AT NODE          2   DOF  4
   INSTANCE:
 LARGEST INCREMENT OF ROTATION      -23.8       AT NODE         46   DOF  4
   INSTANCE: GUANDAO1
 LARGEST CORRECTION TO ROTATION     -23.8       AT NODE         46   DOF  4
   INSTANCE: GUANDAO1
          MOMENT    EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE.
  NUMBER OF EQUATIONS =    27762     NUMBER OF FLOATING PT. OPERATIONS =  1.74E+09
  USING THE DIRECT SOLVER WITH   4 PROCESSORS
     CHECK POINT   START OF SOLVER
     CHECK POINT  END OF SOLVER
       ELAPSED USER TIME (SEC)      =  0.50000
       ELAPSED SYSTEM TIME (SEC)    =  0.10000
       ELAPSED TOTAL CPU TIME (SEC) =  0.60000
       ELAPSED WALLCLOCK TIME (SEC) =          1
 ***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE
             GUANDAO1.148 D.O.F. 2 RATIO = 167.536E+12  .
             GUANDAO1.148 D.O.F. 3 RATIO = 242.816E+12  .
               CONVERGENCE CHECKS FOR EQUILIBRIUM ITERATION     2
 AVERAGE FORCE                       16.9       TIME AVG. FORCE        16.9
 LARGEST RESIDUAL FORCE              4.99       AT NODE       1485   DOF  2
   INSTANCE: GUANDAO1
 LARGEST INCREMENT OF DISP.        -2.561E+05   AT NODE        605   DOF  2
   INSTANCE: GUANDAO1
 LARGEST CORRECTION TO DISP.       -2.569E+05   AT NODE        605   DOF  2
   INSTANCE: GUANDAO1
 AVERAGE MOMENT                      1.17       TIME AVG. MOMENT       1.17
 LARGEST RESIDUAL MOMENT           -0.345       AT NODE          3   DOF  5
   INSTANCE:
 LARGEST INCREMENT OF ROTATION       407.       AT NODE        292   DOF  4
   INSTANCE: GUANDAO1
 LARGEST CORRECTION TO ROTATION      430.       AT NODE         46   DOF  4
   INSTANCE: GUANDAO1
       ELAPSED USER TIME (SEC)      =  0.60000
       ELAPSED TOTAL CPU TIME (SEC) =  0.70000
       ELAPSED WALLCLOCK TIME (SEC) =          0
             GUANDAO1.148 D.O.F. 2 RATIO = 178.205E+12  .
             GUANDAO1.148 D.O.F. 3 RATIO = 95.3996E+12 .
问一下,这些警告是不是因为计算不收敛的原因呢?怎么解除这些警告呢?因为一个模型计算了很久都不收敛,找不到原因,最近一直在查找问题。还望知道的人解答一下,谢谢了
易炜
是不是自由度约束的不够。或者接触出的错。
2017年2月11日
