chemkin使用问题,qq814327517?
浏览:1516 回答:4
 chemkin软件使用
chemkin使用问题,qq814327517?的图1
chemkin使用问题,qq814327517?的图2
chemkin使用问题,qq814327517?的图3
     *               ANSYS Chemkin 17.0 Release 15151                *
     *                      AURORA Application                       *
     *         PERFECTLY STIRRED OR PLUG FLOW REACTOR MODEL          *
     * Copyright(c) 1997-2013 Reaction Design.  All Rights Reserved. *
Running CHEMKIN-PRO
Running Multi-threaded mode
                WORKING SPACE REQUIREMENTS
                 PROVIDED        REQUIRED
 LOGICAL               82             82
 INTEGER             4725           4725
 REAL                5975           5975
 CHARACTER             60             60
This problem requires      0.046MB of memory for the REAL array.
Initializing CHEMKIN Gas-phase Library a component of ANSYS Chemkin 17.0 Release 15151, Build date: Jan 18, 2016
This and All Other CHEMKIN(R) Libraries are Copyright (c) 1997-2013 Reaction Design.  All rights reserved.
LICENSE INFORMATION:
LicNum: 0
           KEYWORD INPUT
          ! problem type definition
          ENRG   ! Solve Gas Energy Equation
          STST   ! Steady State Solver
          ! physical property
          !Surface_Temperature   ! Surface Temperature Same as Gas Temperature
          PRES 1.0   ! Pressure (atm)
          QLOS 0.0   ! Heat Loss (cal/sec)
          TAU 2.0   ! Residence Time (sec)
          TEMP 800.0   ! Temperature (K)
          TINL 1300.0   ! Inlet Temperature (K)
          VOL 1.0   ! Volume (cm3)
          ! species property
          REAC H2O 0.4   ! Reactant Fraction (mole fraction)
          REAC HCL 0.5   ! Reactant Fraction (mole fraction)
          REAC HG 1.85E-6   ! Reactant Fraction (mole fraction)
          REAC N2 3.6   ! Reactant Fraction (mole fraction)
          REAC O2 0.5   ! Reactant Fraction (mole fraction)
          ! solver control
          ATIM 1.0E-9   ! Absolute Tolerance for Pseudo Timestepping
          ATOL 1.0E-9   ! Absolute Tolerance
          DTMN 1.0E-10   ! Minimum Pseudo Time Step (sec)
          DTMX 0.01   ! Maximum Pseudo Time Step (sec)
          IRET 25   ! Number Time Steps Before Increasing
          ISTP 0   ! Number of Initial Pseudo Time Steps
          MAXTIME 100   ! Maximum Number of Pseudo Time Stepping Operations Allowed
          NJAC 20   ! Number of Iterations before Updating Jacobian
          RTIM 0.0001   ! Relative Tolerance for Pseudo Timestepping
          RTOL 0.0001   ! Relative Tolerance
          SFLR -0.0001   ! Minimum Bounds on Species Fractions
          SSMAXITER 100   ! Maximum Number of Iterations per Steady State Search
          TIM1 100.0 1.0E-6   ! Pseudo Time Steps (Fixed Temperature) (none, sec)
          TIM2 100.0 1.0E-6   ! Pseudo Time Steps (Energy Equation) (none, sec)
          TJAC 20   ! Number of Transient Iterations before Updating Jacobian
          TRMAXITER 25   ! Maximum Number of Iterations per Pseudo Time Step
          ! output control and other misc. property
          DFAC 2.0   ! Time Step Decrement Factor
          EPSR 0.01   ! Threshold for Rate of Production
          EPSS 0.001   ! Threshold for Species Sensitivity
          EPST 0.001   ! Threshold for Temperature Sensitivity
          GFAC 1.0   ! Gas Reaction Rate Multiplier
          PRNT 1   ! Print Level Control
          SIZE 10000000   ! Solution Data Block Size (bytes)
          UFAC 2.0   ! Time Step Increment Factor
          ! Number of Continuation 0   ! Continuation Count
          END
  CAUTION...REACTANT MOLE FRACTIONS SUM TO    5.00000185000000
          FOR STREAM INLET1
          MOLE FRACTIONS WILL BE NORMALIZED.
 FIRST SOLUTION ESTIMATE FOR PSR #  1 IS EQUILIBRIUM
     KINETICS MECHANISM:
        Total number of gas phase species     =   21
        Total number of gas phase reactions   =   32
     REACTOR #    1 CONDITIONS FOR INLET NAMED: INLET1
          Residence time in reactor =    2.00     sec
               (which, based on an estimated reactor density =   4.611E-04 gm/cm^3
                       and on a reactor volume  =    1.00     cm^3,
                produces an estimated inlet mass flow rate) =   2.306E-04 gm/sec
          Inlet temperature =   1300.0     Kelvin
          Inlet pressure (assumed equal to reactor pressure) =    1.00     atm
          Inlet density =  2.66763E-04 gm/cm^3
          Inlet mean molecular weight =   28.457     gm/mole
          Inlet molar flow rate      =  8.10240E-06 moles/sec
          Inlet volumetric flow rate =  0.86432     cm^3/sec
               (based on reactor pressure and inlet temperature)
                                     =   11.894     SCCM
                                     =  1.18937E-02 SLPM
     INLET CONDITIONS FOR GAS PHASE MOLECULAR SPECIES IN INLET1
   Species        mole_frac     moles/sec       gm/sec       cm^3/sec        SCCM            SLPM
    HG          3.70000E-007  2.99789E-012  6.01346E-010  3.19799E-007  4.40068E-006  4.40068E-009
    CL           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    CL2          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HGCL         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HOCL         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    H            0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    H2           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    O            0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    OH           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    H2O         8.00000E-002  6.48192E-007  1.16774E-005  6.91457E-002  0.95150       9.51497E-004
    CLO          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HO2          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    O2          0.10000       8.10240E-007  2.59267E-005  8.64321E-002   1.1894       1.18937E-003
    H2O2         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    CLO2         0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    HGO          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    N2          0.72000       5.83372E-006  1.63422E-004  0.62231        8.5635       8.56348E-003
    HCL         0.10000       8.10240E-007  2.95421E-005  8.64321E-002   1.1894       1.18937E-003
    HGCL2        0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    O3           0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
    N2O          0.0000        0.0000        0.0000        0.0000        0.0000        0.0000
 TWOPNT:  DOUBLE PRECISION (TWO POINT BOUNDARY VALUE PROBLEM) SOLVER,
          VERSION 3.30 OF APRIL 1998 BY DR. JOSEPH F. GRCAR.
 TWOPNT:  INITIAL GUESS:
                              PSPRNT: Printing of current solution from TWOPNT:
               RESIDENCE TIME                  2.0000E+00  SEC
               MASS FLOW RATE                  2.3057E-04  GM/SEC
               PRESSURE                        1.000      ATM
               MASS DENSITY                   4.6114E-04  GM/CM^3
               VOLUME                          1.000      CM^3
               TOTAL MASS                     4.6114E-04  G
               TOTAL SURFACE AREA              0.000      CM^2
               TOTAL SURFACE TO VOLUME RATIO   0.000      CM-1
               GAS CHEM HEAT PRODUCTION       -4.4827E-19  CAL/S/CM^3
               TEMPERATURE (FIXED)              800.0000  K
               SURF TEMP, MATERIAL1             800.0000  K  (same as gas temp)
   INLET  GAS PHASE MOLE FRACTIONS
    HG              =  3.7000E-007       CL              =  0.0000E+000       CL2             =  0.0000E+000
    HGCL            =  0.0000E+000       HOCL            =  0.0000E+000       H               =  0.0000E+000
    H2              =  0.0000E+000       O               =  0.0000E+000       OH              =  0.0000E+000
    H2O             =  8.0000E-002       CLO             =  0.0000E+000       HO2             =  0.0000E+000
    O2              =  1.0000E-001       H2O2            =  0.0000E+000       CLO2            =  0.0000E+000
    HGO             =  0.0000E+000       N2              =  7.2000E-001       HCL             =  1.0000E-001
    HGCL2           =  0.0000E+000       O3              =  0.0000E+000       N2O             =  0.0000E+000
   EXIT    GAS PHASE MOLE FRACTIONS
    HG              =  3.9268E-007       CL              =  7.8532E-008       CL2             =  7.1236E-005
    HGCL            =  8.9109E-010       HOCL            =  3.2909E-008       H               =  2.3198E-018
    H2              =  6.4713E-013       O               =  7.9793E-016       OH              =  1.5369E-010
    H2O             =  1.2767E-001       CLO             =  2.3917E-012       HO2             =  8.7422E-014
    O2              =  1.0222E-004       H2O2            =  1.3788E-013       CLO2            =  8.4992E-002
    HGO             =  3.6569E-018       N2              =  7.6592E-001       HCL             =  2.1243E-002
    HGCL2           =  2.5533E-011       O3              =  1.2177E-019       N2O             =  4.3099E-012
   NOx                      (ppmvd): 4.9406E-06
   NOx               (ppmvd 15% O2): 1.4124E-06
 TWOPNT:  SOLVE THE PROBLEM.
                      LOG10   LOG10
              TASK   NORM F  COND J   REMARK
             START    -1.02
            SEARCH    -7.07    0.00   10 SEARCH STEPS
 TWOPNT:  FINAL SOLUTION:
               MASS FLOW RATE                  2.1675E-04  GM/SEC
               PRESSURE                        1.000      ATM
               MASS DENSITY                   4.3349E-04  GM/CM^3
               VOLUME                          1.000      CM^3
               TOTAL MASS                     4.3349E-04  G
               GAS CHEM HEAT PRODUCTION        1.0356E-08  CAL/S/CM^3
    HG              =  3.7000E-007       CL              = -2.5855E-010       CL2             =  1.2625E-010
    HGCL            = -3.1017E-012       HOCL            = -3.7046E-010       H               =  1.2721E-017
    H2              =  1.0529E-022       O               =  3.7773E-010       OH              = -5.8458E-012
    H2O             =  8.0000E-002       CLO             = -1.3646E-018       HO2             =  7.1585E-021
    O2              =  1.0000E-001       H2O2            =  1.0164E-023       CLO2            =  6.2597E-012
    HGO             =  2.7444E-018       N2              =  7.2000E-001       HCL             =  1.0000E-001
    HGCL2           =  2.3362E-013       O3              =  2.2262E-024       N2O             =  3.1742E-022
   NOx                      (ppmvd): 3.4502E-16
   NOx               (ppmvd 15% O2): 2.0435E-16
 TWOPNT:  SUCCESS.  PROBLEM SOLVED.
   PSRTWO: FINISHED FIXED TEMPERATURE, ADDING ENERGY EQUATION
               PRESSURE                        1.000      ATM
               VOLUME                          1.000      CM^3
               TEMPERATURE (INLET)             1300.0000  K
               TEMPERATURE                      800.0000  K
               HEAT LOSS, MATERIAL1            0.000      CAL/SEC
                      LOG10   LOG10
             START     2.42
            SEARCH    -3.11    0.00   13 SEARCH STEPS
               MASS FLOW RATE                  1.3338E-04  GM/SEC
               PRESSURE                        1.000      ATM
               MASS DENSITY                   2.6676E-04  GM/CM^3
               VOLUME                          1.000      CM^3
               TOTAL MASS                     2.6676E-04  G
               GAS CHEM HEAT PRODUCTION       -2.5986E-07  CAL/S/CM^3
               TEMPERATURE                     1299.9997  K
               SURF TEMP, MATERIAL1            1299.9997  K  (same as gas temp)
    HG              =  3.7000E-007       CL              =  4.3647E-008       CL2             = -2.1889E-008
    HGCL            =  1.2433E-013       HOCL            = -1.4348E-010       H               = -1.4140E-013
    H2              = -9.1662E-019       O               =  8.6010E-014       OH              =  4.1713E-010
    H2O             =  8.0000E-002       CLO             = -4.5839E-018       HO2             =  2.5515E-015
    O2              =  1.0000E-001       H2O2            =  1.0240E-023       CLO2            =  7.5114E-019
    HGO             =  3.9924E-018       N2              =  7.2000E-001       HCL             =  1.0000E-001
    HGCL2           =  6.9424E-014       O3              =  5.6680E-019       N2O             =  4.7248E-023
   NOx                      (ppmvd): 5.1357E-17
   NOx               (ppmvd 15% O2): 3.0417E-17
     OUTLET CONDITIONS:
          Specified residence time in reactor =    2.00     sec
               (which, based on a reactor density  =   2.668E-04 gm/cm^3
                 produces an inlet mass flow rate) =   1.334E-04 gm/sec
          Outlet mass flow rate          =   1.334E-04 gm/sec
          Rate of Mass Loss to the walls =    0.00     gm/sec
          Outlet and reactor temperature =   1300.0     Kelvin
          Outlet and reactor pressure    =    1.00     atm
          Outlet and reactor density     =  2.66764E-04 gm/cm^3
          Outlet and reactor mean molecular weight =   28.457     gm/mole
          Outlet molar flow rate         =  4.68715E-06 moles/sec
          Outlet volumetric flow rate    =  0.50000     cm^3/sec
               (based on reactor pressure and temperature)
                                         =   6.8804     SCCM
                                         =  6.88039E-03 SLPM
     OUTLET CONDITIONS FOR GAS PHASE MOLECULAR SPECIES:
   Species        mole_frac     #/cm^3       moles/sec       gm/sec       cm^3/sec        SCCM
    HG           3.70000E-07   2.08877E+12   1.73424E-12   3.47872E-10   1.85000E-07   2.54574E-06
    CL           4.36471E-08   2.46402E+11   2.04580E-13   7.25299E-12   2.18235E-08   3.00309E-07
    CL2         -2.18889E-08  -1.23570E+11  -1.02597E-13  -7.27472E-12  -1.09445E-08  -1.50604E-07
    HGCL         1.24332E-13   7.01894E+05   5.82761E-19   1.37557E-16   6.21659E-14   8.55450E-13
    HOCL        -1.43475E-10  -8.09965E+08  -6.72489E-16  -3.52790E-14  -7.17375E-11  -9.87164E-10
    H           -1.41402E-13  -7.98261E+05  -6.62771E-19  -6.68054E-19  -7.07009E-14  -9.72899E-13
    H2          -9.16621E-19   -5.1746      -4.29634E-24  -8.66116E-24  -4.58310E-19  -6.30670E-18
    O            8.60100E-14   4.85555E+05   4.03142E-19   6.45003E-18   4.30050E-14   5.91782E-13
    OH           4.17134E-10   2.35486E+09   1.95517E-15   3.32522E-14   2.08567E-10   2.87004E-09
    H2O          8.00000E-02   4.51627E+17   3.74972E-07   6.75524E-06   4.00000E-02   0.55043
    CLO         -4.58387E-18   -25.877      -2.14853E-23  -1.10547E-21  -2.29193E-18  -3.15388E-17
    HO2          2.55145E-15    14404.       1.19590E-20   3.94729E-19   1.27573E-15   1.75550E-14
    O2           0.10000       5.64533E+17   4.68715E-07   1.49983E-05   5.00000E-02   0.68804
    H2O2         1.02396E-23   5.78058E-05   4.79944E-29   1.63252E-27   5.11979E-24   7.04522E-23
    CLO2         7.51139E-19    4.2404       3.52070E-24   2.37478E-22   3.75570E-19   5.16813E-18
    HGO          3.99240E-18    22.538       1.87130E-23   4.05303E-21   1.99620E-18   2.74692E-17
    N2           0.72000       4.06464E+18   3.37475E-06   9.45381E-05   0.36000        4.9539
    HCL          0.10000       5.64533E+17   4.68715E-07   1.70898E-05   5.00000E-02   0.68804
    HGCL2        6.94243E-14   3.91923E+05   3.25402E-19   8.83454E-17   3.47122E-14   4.77666E-13
    O3           5.66800E-19    3.1998       2.65667E-24   1.27516E-22   2.83400E-19   3.89980E-18
    N2O          4.72481E-23   2.66731E-04   2.21459E-28   9.74702E-27   2.36241E-23   3.25085E-22
                         DETAILED SPECIES BALANCE
                                   (all rates are in moles per sec)
   SPECIES           INLET_FR    OUTLET_FR  GAS_PROD_RATE  GAS_DEST_RATE   SURF_NET_PROD    TOTAL_NET
 HG                   1.734E-12     1.734E-12     1.940E-14     1.901E-14      0.00         3.878E-16
 CL                    0.00         2.046E-13     5.618E-12     4.922E-14      0.00         5.364E-12
 CL2                   0.00        -1.026E-13     2.450E-14    -2.129E-16      0.00         1.273E-13
 HGCL                  0.00         5.828E-19     5.623E-12     1.505E-13      0.00         5.472E-12
 HOCL                  0.00        -6.725E-16     2.200E-17    -1.274E-16      0.00         8.219E-16
 H                     0.00        -6.628E-19     1.312E-13    -1.508E-14      0.00         1.463E-13
 H2                    0.00        -4.296E-24    -4.283E-24    -1.442E-35      0.00         1.332E-26
 O                     0.00         4.031E-19     1.381E-18     5.931E-16      0.00        -5.922E-16
 OH                    0.00         1.955E-15     5.928E-15     4.103E-15      0.00        -1.299E-16
 H2O                  3.750E-07     3.750E-07     4.080E-15     5.463E-15      0.00        -2.524E-13
 CLO                   0.00        -2.149E-23     6.751E-21    -8.213E-24      0.00         6.781E-21
 HO2                   0.00         1.196E-20     1.196E-20     4.823E-29      0.00        -6.859E-26
 O2                   4.687E-07     4.687E-07     1.045E-27     1.196E-20      0.00        -3.153E-13
 H2O2                  0.00         4.799E-29     4.799E-29     2.362E-40      0.00         5.445E-34
 CLO2                  0.00         3.521E-24    -1.635E-33     1.098E-36      0.00        -3.521E-24
 HGO                   0.00         1.871E-23    -8.212E-24     6.754E-21      0.00        -6.781E-21
 N2                   3.375E-06     3.375E-06     6.880E-39     2.273E-28      0.00        -2.270E-12
 HCL                  4.687E-07     4.687E-07    -9.617E-15     1.359E-13      0.00        -4.621E-13
 HGCL2                 0.00         3.254E-19     1.311E-13     5.604E-12      0.00        -5.472E-12
 O3                    0.00         2.657E-24     2.727E-24     1.045E-27      0.00         6.900E-26
 N2O                   0.00         2.215E-28     2.273E-28     6.880E-39      0.00         5.866E-30
                         DETAILED ELEMENT BALANCES
 ELEMENT          INLET_FR      OUTLET_FR    TOTAL_NET
 C                   0.00          0.00          0.00
 O                  1.312E-06     1.312E-06    -8.829E-13
 CL                 4.687E-07     4.687E-07    -3.153E-13
 HG                 1.734E-12     1.734E-12    -1.167E-18
 H                  1.219E-06     1.219E-06    -8.198E-13
 N                  6.749E-06     6.749E-06    -4.541E-12
 Total CPUtime: 1 second or less
文件压缩包链接:http://pan.baidu.com/s/1mh8dHhe 密码:04ki     想做出别人论文第16页效果
结构力学
问题描述清楚点啊,而且如果想单独沟通,最好去发布一个协作任务
2017年2月17日
评论 2 点赞
技术工
@液风@龙樱@Big_Ocean@steve_zheng
2017年2月16日
