Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ansys非线性分析不收敛,求大神解答?
浏览: 2344 回答: 5
麻烦各位帮我看看为什么计算结果不收敛,这个模型是在模拟拉索锚固区受力,很简单的模型,最后总是提醒:
 One or more elements have become highly distorted.  Excessive
 distortion of elements is usually a symptom indicating the need for
 corrective action elsewhere.  Try incrementing the load more slowly
 (increase the number of substeps or decrease the time step size).  You
 may need to improve your mesh to obtain elements with better aspect
 ratios.  Also consider the behavior of materials, contact pairs,
 and/or constraint equations.  If this message appears in the first
 iteration of first substep, be sure to perform element shape checking.
不知如何解决,命令流如下,需要导入截面,无法上传还请见谅。
FINI
/CLEAR,START
/AUX15
~SATIN,'small','sat',,ALL,0   !从CAD输出的.sat文件导入小截面small
/NOPR
/PREP7
!0. 定义变量(单位采用N-mm制)------------------------------
!注:不设置密度DENS,即不考虑重力影响
EMCI=2.1e5         !锚杯铸钢ZG20Mn弹性模量 ELASTICITY MODULOUS OF CAST
IRON
EMP=1.5e5          !热铸锌铜合金弹性模量 ELASTICITY MODULOUS OF PLATINE
!1. 定义单元、材料属性及截面---------------------------
ET,1,SOLID187       !铸体、锚杯
MP,EX,1,EMCI        !锚杯材料特性,考虑材料非线性,采用多线性等向强化模
型MISO
MP,PRXY,1,0.3
TB,MISO,1,,3
TBPT,,0.001905,400
TBPT,,0.003,401
TBPT,,0.021,625
MP,EX,2,EMP         !铸体材料特性,考虑材料非线性,采用多线性等向强化模
型MISO
MP,PRXY,2,0.27
TB,MISO,2,,3
TBPT,,0.002667,400
TBPT,,0.003,401
TBPT,,0.021,625
R,1                  !锚杯实常数
R,2                  !铸体实常数
!2.1 铸体几何模型建立----------------------------
AGLUE,ALL
LGLUE,ALL
NUMMRG,ALL
NUMCMP,ALL
ASEL,S,LOC,Z,0
CM,DY1,AREA           !定义组件“定位1”
PCIRC,36.5
ASEL,S,LOC,Z,0
ASEL,R,LOC,Y,0
ASEL,R,LOC,X,0
CM,LK1,AREA           !定义组件“轮廓1”
ALLSEL,ALL
ASBA,LK1,DY1,0,DELETE,KEEP
VEXT,ALL,,,,,435,2.386767,2.386767
VATT,2,2,1            !分别表示材料号、实常数号、单元类型号
!2.2 锚杯几何模型建立----------------------------
NUMSTR,KP,1001
NUMSTR,LINE,1001
NUMSTR,AREA,1001
NUMSTR,VOLU,1001
CSYS,0
K, 1001  ,0,83.000,495.000,
K, 1002  ,0,83.000,511.000,
K, 1003  ,0,83.000,516.000,
K, 1004  ,0,87.000,520.000,
K, 1005  ,0,120.000,520.000,
K, 1006  ,0,125.000,515.000,
K, 1007  ,0,125.000,511.000,
K, 1008  ,0,125.000,495.000,
K, 1009  ,0,125.000,436.288,
K, 1010  ,0,79.306,115.643,
K, 1011  ,0,118.905,70.000,
K, 1012  ,0,125.000,70.000,
K, 1013  ,0,125.000,2.000,
K, 1014  ,0,123.000,.000,
L,260,1001
L,1001,1002
L,1002,1003
L,1003,1004
L,1004,1005
L,1005,1006
L,1006,1007
L,1007,1008
L,1008,1009
L,1009,1010
L,1010,1011
L,1011,1012
L,1012,1013
L,1013,1014
L,1014,129
LSEL,S,LINE,,1001,1015
LSEL,A,LINE,,745
AL,ALL
VROTAT,1001,,,,,,33,138,,4      !面绕着旋转轴生成体
ALLS
NUMMRG,ALL
VSEL,S,,,1001,1004
VATT,1,1,1                      !分别表示材料号、实常数号、单元类型号
!3. 网格划分----------------------------
LSEL,S,LOC,Z,1,434
CSWPLA,11,1
LSEL,R,LOC,X,-60,60
CSYS,0
LESIZE,ALL,,,40
ALLS
LSEL,S,,,1,1000
LSEL,U,LOC,Z,100,300
LSEL,R,LENGTH,,1,20
LESIZE,ALL,,,1
ALLS
LSEL,S,,,1,1000
LSEL,U,LENGTH,,1,20
LESIZE,ALL,,,12
ALLS
MSHAPE,1,3D
MSHKEY,0
SMRTSIZE,3
VMESH,ALL
!*GET,AA,ELEM,0,COUNT
!*STATUS,AA                     !查询单元数量
!4. 施加荷载及边界条件----------------------------
ALLS
NSEL,S,LOC,Z,0
CSWPLA,11,1
NSEL,R,LOC,X,100,10000
CSYS,0
D,ALL,ALL
ALLS
LSEL,S,LOC,Z,0
LSEL,R,LENGTH,,1,10
NSLL,S,1
F,ALL,FZ,-10000
ALLSEL,ALL
FINI
/SOLU
CNVTOL,U,,0.05,2              !位移的收敛准则为0.05
CNVTOL,F,,0.01,2,1            !位移的收敛准则为0.01
ANTYPE,0                      !定义分析类型:静态分析
NLGEOM,ON                     !几何非线性开关
TIME,1                        !荷载步结束时的时间值
NSUBST,10                     !荷载步的子步数
OUTRES,ALL,ALL
AUTOTS,ON                     !自动时间步
NEQIT,50                      !平衡迭代的最大次数
SOLVE
FINISH
!5. 后处理-------------------------
/POST1
SET,LAST                      !查看某个时刻的计算结果
PLDISP,2                      !显示结构变形图
PLESOL,S,X,0                  !显示单元X方向应力
PLESOL,S,Y,0                  !显示单元Y方向应力
PLESOL,S,Z,0                  !显示单元Z方向应力
FINI
ANSYS 土木工程 有限元理论及编程
全部回答 (3)
大龙猫🐱 2017年2月20日
NSUBST,10 !荷载步的子步数 调多到100,或者是你的模型网格太稀疏了,默认网格试试看
2017年2月20日
宁博士CAE团队 2017年2月19日
你把small.sat也传上去,别人就可以调试了
2017年2月19日
韩罗峰 2017年2月19日
提醒网格需要加密。多分几个载荷步,加载更慢些,容易收敛。
2017年2月19日
相似问题
查看全部
  • ansys钢筋混凝土锈蚀模拟过程中的问题? 3个回答
    ansys初学者,根据导师的论文想要做一个关于混凝土锈蚀的模拟,计算的时候出现如下提示,能力有限,自己检查了很多遍也没发现问题,希望各位大神帮忙解答,后附命令流,谢谢大家 finish /clear /filname,rcbeam /prep7 et,1,solid65 !混凝土 et,2,solid45 !垫块 et,3,link8 !钢筋 et,4,combin39 !弹簧 keyopt,1,
  • 本构关系问题?具体怎么改呢? 暂无回答
    FINISH /CLEAR /FILNAME,BEAM /PREP7 PI=3.1415926 L=3100 LP=1000 W=200 H=300 P=25 R_PS=4 A_PS=0.25*PI*R_PS**2 R_TS=9 A_TS=0.25*PI*R_TS**2 R_GS=4 A_GS=0.25*PI*R_GS**2 FY=350E6 Q=1E6 E0=2E9 EX_C=30E9 PRXY
  • 各位大神好,在下按书上例子用分离式建了一个钢筋混凝土简支梁可以收敛,但是计算结果是错的,命令流如下? 暂无回答
    /CONFIG,NRES,2000 /PREP7 ET,1,SOLID65 KEYOPT,1,1,1 KEYOPT,1,3,2 KEYOPT,1,7,1 ET,2,LINK180 ET,3,solid45 MP,EX,1,21945E6 MP,PRXY,1,0.2 FC=23.1E6 FT=1.89E6 TB,CONCR,1 TBDATA,,0.5,0.95,FT,-1 TB,MISO,1,,10
推荐阅读
【专题课程】ANSA HEXABLOCK六面体网格划分专题(完结)
Wonderful仿真 Wonderful仿真
¥399
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
测量误差与测量不确定度
测量误差与测量不确定度
HBK测试与测量 HBK测试与测量
免费
Apex For Aerospace Applications Introduction
MSC Apex
免费
公路钢筋混凝土及预应力混凝土桥涵设计规范解决方案
敦樸DUNPU 敦樸DUNPU
免费
慧加新规范解决方案详解之大跨连续弯梁桥精细化分析(7DOF)
敦樸DUNPU 敦樸DUNPU
免费
混合弯头的流体流动与传热
混合弯头的流体流动与传热
CFD流 CFD流
免费
Abaqus子程序安装教程 Abaqus6.14.2+VS2013+IVF2013(附带安装包)
二十 二十
免费
北京华盛扬科技 北京华盛扬科技
¥9.9
Msc Apex For Aerospace Applications Idealization a
MSC Apex
免费
超大规模芯片电源完整性签核平台RedHawk-SC应用分享
Ansys中国 Ansys中国
免费
ALTAIR ALTAIR
免费
结构仿真职业规划与学习路线
结构仿真职业规划与学习路线
技术邻直播 技术邻直播
免费
人工智能工程应用实例: 发动机排放数据学习及预测
IDAJ中国 IDAJ中国
¥99
Altair二次开发答疑&典型案例解读
Altair二次开发答疑&典型案例解读
ALTAIR ALTAIR
¥10
MATLAB/ADAMS求解动力学
MATLAB/ADAMS求解动力学
伟_sss 伟_sss
¥25
基于OptiSturct的线性静力学分析和尺寸优化
Leon_sun Leon_sun
¥10
Abaqus在高科技与电子行业的应用(达索直播课程)
水木人CAE-林丽 水木人CAE-林丽
¥10
AQWA软件企业培训(3)  通过ANSYS-APDL建立半潜平台混合模型及混合模型的拖曳力线性化
Nutshell Nutshell
¥30
SpaceClaim直接建模
SpaceClaim直接建模
技术邻小李 技术邻小李
¥80
