顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
仿真结果不满意???
浏览: 2287 回答: 5
第二幅图,是工具头轨迹,可是第一第三幅应变图上,明显不是圆。在最初加工时显示都是圆,但是越往下走,圆就慢慢变成了类似菱形的样子,这是为什么???工具头轨迹是没有问题的,望大神指导。。。
轨迹导入采用的是amplitude-smooth step
** MATERIALS
*Material, name=Material-1
*Density
 2.7e-09,
*Elastic
71000., 0.34
*Plastic
 90.,      0.
131., 0.00159
171., 0.00649
211.,  0.0177
251.,  0.0395
291.,  0.0776
331.,   0.139
391.,   0.295
** INTERACTION PROPERTIES
*Surface Interaction, name=IntProp-1
*Friction
 0.2,
*Surface Interaction, name=IntProp-2
*Friction
 0.1,
** BOUNDARY CONDITIONS
** Name: BC-2 Type: Displacement/Rotation
*Boundary
ban, 1, 1
ban, 2, 2
ban, 3, 3
ban, 4, 4
ban, 5, 5
ban, 6, 6
** Name: BC-3 Type: Displacement/Rotation
*Boundary
rfxiaban, 1, 1
rfxiaban, 2, 2
rfxiaban, 3, 3
rfxiaban, 4, 4
rfxiaban, 5, 5
rfxiaban, 6, 6
** Name: BC-X Type: Displacement/Rotation
*Boundary
rftool, 1, 1
** Name: BC-Y Type: Displacement/Rotation
*Boundary, amplitude=Amp-equallyY
rftool, 2, 2
** Name: BC-Z Type: Displacement/Rotation
*Boundary
rftool, 3, 3
** Name: BC-rftoolfix Type: Displacement/Rotation
*Boundary
rftool, 4, 4
rftool, 5, 5
** Name: BC-toolrotation Type: Velocity/Angular velocity
*Boundary, type=VELOCITY
rftool, 6, 6
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES
*Dynamic, Explicit
, 60.22
*Bulk Viscosity
0.06, 1.2
** Mass Scaling: Semi-Automatic
**               Whole Model
*Fixed Mass Scaling, factor=200.
*Boundary, op=NEW
ban, 1, 1
ban, 2, 2
ban, 3, 3
ban, 4, 4
ban, 5, 5
ban, 6, 6
*Boundary, op=NEW
rfxiaban, 1, 1
rfxiaban, 2, 2
rfxiaban, 3, 3
rfxiaban, 4, 4
rfxiaban, 5, 5
rfxiaban, 6, 6
*Boundary, op=NEW, amplitude=Amp-smoothX
rftool, 1, 1, 1.
*Boundary, op=NEW, amplitude=Amp-smoothY
rftool, 2, 2, 1.
*Boundary, op=NEW, amplitude=Amp-smoothZ
rftool, 3, 3, 1.
*Boundary, op=NEW
rftool, 4, 4
rftool, 5, 5
*Boundary, op=NEW, type=VELOCITY
rftool, 6, 6, 1000.
** INTERACTIONS
** Interaction: Int-1
*Contact Pair, interaction=IntProp-1, mechanical constraint=PENALTY, cpset=Int-1
Surf-tool, Surf-bantop
** Interaction: Int-2
*Contact Pair, interaction=IntProp-2, mechanical constraint=PENALTY, cpset=Int-2
Surf-xiaban, Surf-banbottom
** OUTPUT REQUESTS
*Restart, write, overlay, number interval=1, time marks=NO
** FIELD OUTPUT: F-Output-1
*Output, field, number interval=5000
*Node Output, nset=Part-3dplan-1.Set-ban
U,
*Element Output, elset=Part-3dplan-1.Set-ban, directions=YES
MISES, PE, PEEQ, S, STH
** FIELD OUTPUT: F-Output-2
*Node Output, nset=b_Set-tool
U, V
** HISTORY OUTPUT: H-Output-1
*Output, history, time interval=0.00669111
*Energy Output
ETOTAL,
** HISTORY OUTPUT: H-Output-2
*Element Output, elset=Set-banelement
STH,
** HISTORY OUTPUT: H-Output-3
*Node Output, nset=rftool
VR3,
*End Step
ABAQUS 结构CAE 显式动力学及仿真
全部回答 (2)
小月 2017年2月22日
把inp附上来,看看
2017年2月22日
评论 3 点赞
干货有限元 2017年2月22日
看着好像沙漏比较严重
2017年2月22日
相似问题
查看全部
  • inp文件引入接触出错,请问是什么原因? 4个回答
    错误信息: *CONTACT PROPERTY ASSIGNMENT CAN ONLY REFERENCE SURFACE INTERACTIONS WHICH ARE DEFINED AS MODEL DATA. SEE THE SURFACE INTERACTION NAMED INTPROP-1. inp文件: *Heading ** Job name: Job-1 Model name:
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
  • inp文件中已经删除相应单元,显示未定义属性? 1个回答
    part-1只留下一个PD3D单元,其余都删了,为什么还会说没定义属性 error信息: 1 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection. inp文件: *Heading ** Job name: Job-2 Mo
推荐阅读
【专题课程】ANSA HEXABLOCK六面体网格划分专题(完结)
Wonderful仿真 Wonderful仿真
¥399
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
abaqus模拟桩(三维)全过程
abaqus模拟桩(三维)全过程
红日当空q3120210076 红日当空q3120210076
¥62
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
TurboTides TurboTides
免费
