Nastan 频响分析,有报错,但还是计算完了,不知道报错如何解决?
浏览:1285 回答:1
17:13:17 Solution of the system equations for frequency response started.
17:13:17 Solution of the system equations for frequency response successfully completed.
17:13:17 183673 records read from JID file "c:/users/administrator/desktop/fe-57/frequency_analysis/fe_5 no damper6.bdf"
17:13:17 NSEXIT: EXIT(20)
17:13:17 Analysis complete -20
-20意思就是没有算完的吧?然后搜f06有个fatal,如下:
*** USER FATAL MESSAGE 2170 (PARTN2)
BOTH THE ROW AND COLUMN PARTITIONING VECTORS ARE PURGED AND ONLY ONE MAY BE.
0FATAL ERROR
1 * * * END OF JOB * * *
请问这个fatal是什么意思?从哪里去着手解决,百度下查报错代码也没查到。
