关于k文件修改的问题,请老师们帮帮我?
浏览:2317 回答:7
最近在做一个隧道爆破的例子,k文件在输入求解器时总是错误不断,我在网上也百度解决了一些问题,剩下的网上并没有解决办法,
                      希望老师们能帮帮我!
以下是错误信息:
 *** Warning 10137 (KEY+137)
     Multiple defined SECTION ID SECTION 0
     (Check input as errors may result)
 *** Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 1
     The default hourglass properties of the following
     ALE part are being modified to avoid unnecessary
     application of hourglass forces.
     Resetting coefficient qm=1.0e-6.
     PART ID 1 with
     MATERIAL ID 1 and
     EOS ID 1
     This is PART 1 in the order of input.
 *** Error 10144 (KEY+144)
      part set for multi-material group # 1
     CHECKING MATERIAL INPUT Part ID= 3
     PART ID 3 with
     MATERIAL ID 3 and
     EOS ID 3
     This is PART 3 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 5
     PART ID 5 with
     MATERIAL ID 5 and
     EOS ID 5
     This is PART 5 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 6
     PART ID 6 with
     MATERIAL ID 6 and
     EOS ID 6
     This is PART 6 in the order of input.
      part set for multi-material group # 6
     CHECKING MATERIAL INPUT Part ID= 7
     PART ID 7 with
     MATERIAL ID 7 and
     EOS ID 7
     This is PART 7 in the order of input.
      part set for multi-material group # 7
     CHECKING MULTI-MATERIAL GROUP DEFINITIONS
     part set for initial void parts. # 3
由于K文件太大了,不能上传附件,我就贴一下材料部分的参数
炸药是1,管道是2,衬砌是4,  5、6、7都是围岩。
*MAT_HIGH_EXPLOSIVE_BURN
         1 1.1000000 0.3500000 0.3200000 0.0000000 0.0000000 0.0000000 0.0000000
*EOS_JWL
         1 5.8140002 6.8010E-2 4.1000000 1.0000000 0.3500000 0.0900000 1.0000000
*MAT_ELASTIC
         2  2.40      30.00     0.19      0.00      0.00      0.00      0.00
*EOS_GRUNEISEN
         2  0.00      0.00      0.00      0.00      0.00      0.00      0.00
  0.00
*MAT_NULL
$      MID        RO        PC        MU     TEROD     CEROD        YM        PR
         3     1.000 -3.00E-06      0.00       0.0       0.0       0.0       0.0
*EOS_GRUNEISEN
$    EOSID         C        S1        S2        S3     GAMA0         A        E0
         3    0.1480      2.56     1.986    1.2268      0.50       0.0       0.0
$       V0
       1.0
*MAT_ELASTIC
         4  2.52      35.00     0.19      0.00      0.00      0.00      0.00
*EOS_GRUNEISEN
         4  0.00      0.00      0.00      0.00      0.00      0.00      0.00
  0.00
*MAT_PLASTIC_KINEMATIC
         5  2.43      8.00      0.13      12.00     0.21      0.00      0.00
  0.00      0.00      0.00
*EOS_GRUNEISEN
         5  0.00      0.00      0.00      0.00      0.00      0.00      0.00
  0.00
         6  2.43      8.00      0.13      12.00     0.21      0.00      0.00
  0.00      0.00      0.00
*EOS_GRUNEISEN
         6  0.00      0.00      0.00      0.00      0.00      0.00      0.00
  0.00
         7  2.43      8.00      0.13      12.00     0.21      0.00      0.00
  0.00      0.00      0.00
*EOS_GRUNEISEN
         7  0.00      0.00      0.00      0.00      0.00      0.00      0.00
  0.00
以下部分是section definition:
*SECTION_SOLID_ALE
1,11
*SECTION_SOLID
2,1
*SECTION_SOLID_ALE
3,11
*SECTION_SOLID
4,1
*SECTION_SOLID_ALE
5,11
*SECTION_SOLID_ALE
6,11
*SECTION_SOLID_ALE
7,11
*ALE_MULTI-MATERIAL_GROUP
3,1
5,1
1,1
6,1
7,1
*CONSTRAINED_LAGRANGE_IN_SOLID
1,2,0,0,0,5,3,0
0,0,0.15
*SET_PART_LIST
*SET_PART_LIST
3,4,0,0,0,5,3,0
0,0,0.15
*SET_PART_LIST
*SET_PART_LIST
阿莫西林
楼主你这个问题解决了吗? 我最近在想做隧道爆破的,加个QQ675105858,交流下一下?
2017年3月19日
Jury
10302不用管
2017年3月13日
已采纳 评论 4 点赞
