ansys接触分析报错?
浏览:1098 回答:1
There are 290 small equation solver pivot terms (e.g., at the ROTZ
degree of freedom of node 337). Please check for an insufficiently
constrained model. If you wish to bypass this error message without
resolving the cause of the small pivots, use the PIVCHECK,OFF command.
如上,模型为双层壳接触,顶层壳施加半径预应力,观察底层壳滑移与弯曲情况,建立四分之一壳模型,约束为关于两条直角边对称,中心点处无移动,为何会报错说节点337处ROTZ自由度问题啊(图中红线的点),求大神解答,不胜感激。
