建立钢筋混凝土框架的时候,梁柱利用你tie约束连接的时候出现了问题?
浏览:3642 回答:7
软件:Abaqus
问题:
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
For *tie pair (assembly__pickedsurf609-assembly__pickedsurf608), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf611-assembly__pickedsurf610), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf613-assembly__pickedsurf612), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf321-assembly__pickedsurf320), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf323-assembly__pickedsurf322), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf325-assembly__pickedsurf324), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM
建立钢筋混凝土框架的时候,梁柱利用你tie约束连接的时候出现了问题?的图1新建 WinRAR 压缩文希望大神能帮忙解答,感谢!!
王冬
是啊,同样请教啊
2017年9月22日
Mr李
过约束了吧
2017年3月23日
鲁同学
认认真真提问题没人理吗
2017年3月23日
评论 2 点赞
