abaqus计算钢管桩问题?
浏览:1448 回答:3
对桩进行单向多循环加载,每级荷载施加后,恒载4min后可测读水平位移,然后卸载至零,停2min测读残余水平位移,至此完成一个加卸载循环。如此循环5次,完成一级荷载的位移观测。abaqus模拟这样的试验,但计算到倒数第2步的时候出现这样的错误:The executable D:\SIMULIA\Abaqus\6.11-1\exec\standard.exe aborted with system error code 693. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
请问各位大神这该怎么解决
林ads
问题解决了吗?没有解决可以发我模型看看,QQ442122028
2017年3月26日
栉比鳞臻
先看看这些.dat, .msg, and .sta files 里面的报错吧 听你的描述确实不好判断到底是什么原因 断网、屏保等原因也有可能
2017年3月25日
