fluent并行计算的时候,出现浮点溢出,如何解决?
浏览:19275 回答:3
我先计算了连续相,然后再开DPM模型,采用了DPM模型,设置了两个injection,计算一会后出现了
Divergence detected in AMG solver: temperature
Error at host: floating point exception
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 116980 cells
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error at Node 4: floating point exception
Error at Node 5: floating point exception
Error at Node 6: floating point exception
请问如何解决?网格采用非结构化网格,质量0.4
龙樱
浮点数溢出原因很多,有时并行计算会出现这个错误,单核计算就不会,有时全域初始化会,入口初始化就不会,需要自己调试
2017年3月31日
评论 2 点赞 1
