abaqus问题?
浏览:1234 回答:10
本人abaqus初学者,提交作业出现The executable pre.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.是什么意思??怎样解决?跪求感谢!!!!
