顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
下面的命令流进行静力分析,求解时既不出现solution is done也不出现错误,原因是什么?
浏览: 1551 回答: 8
finish
/clear,all
/PREP7
ET,1,PIPE288
SECTYPE,1,PIPE, ,
SECDATA,32,1.8,0,0,1,0,0,0,
SECOFFSET,0,0,
SECCONTROL,0,
MP,EX,1,2.1e11
MP,PRXY,1,0.3
K,1,-4000,0,0,
K,2,-3736,1500,0,
K,3,-3449,1800,0,
K,4,-3225.6,1999,0,
!K,5,-1919,2850,0,
K,6,-2036,2797.6,0,
K,7,-1253.4,3125.7,0,
K,8,0,3400,0,
K,9,1253.4,3125.7,0,
!K,10,1919,2850,0,
K,11,2036,2797.6,0,
K,12,3225.6,1999,0,
K,13,3449,1800,0,
K,14,3736,1500,0,
K,15,4000,0,0,
K,17,0,1999,0,
LSTR,1,2
LSTR,14,15
LARC,2,8,6
LARC,14,8,11
LSEL,S,,,1,4,1
LATT,1, ,1, , , ,1
LESIZE,ALL, , ,30, ,1, , ,1,
lmesh,1,4,1
ET,2,LINK180
MP,EX,2,2.1e11
MP,PRXY,2,0.3
SECTYPE,2, BEAM, CTUBE, , 0
SECOFFSET, CENT
SECDATA,30.5,32,0,0,0,0,0,0,0,0,0,0
R,2,294.524, ,0
n,122,-3225.6,1999.0,0.0000
n,124,-3010.6,1999.0,0.0000
n,125,-2795.5,1999.0,0.0000
n,126,-2580.5,1999.0,0.0000
n,127,-2365.4,1999.0,0.0000
n,128,-2150.4,1999.0,0.0000
n,129,-1935.4,1999.0,0.0000
n,130,-1720.3,1999.0,0.0000
n,131,-1505.3,1999.0,0.0000
n,132,-1290.2,1999.0,0.0000
n,133,-1075.2,1999.0,0.0000
n,134,-860.16,1999.0,0.0000
n,135,-645.12,1999.0,0.0000
n,136,-430.08,1999.0,0.0000
n,137,-215.04,1999.0,0.0000
n,123,3225.6,1999.0,0.0000
n,138,-0.22737E-12,1999.0,0.0000
n,139,215.04,1999.0,0.0000
n,140,430.08,1999.0,0.0000
n,141,645.12,1999.0,0.0000
n,142,860.16,1999.0,0.0000
n,143,1075.2,1999.0,0.0000
n,144,1290.2,1999.0,0.0000
n,145,1505.3,1999.0,0.0000
n,146,1720.3,1999.0,0.0000
n,147,1935.4,1999.0,0.0000
n,148,2150.4,1999.0,0.0000
n,149,2365.4,1999.0,0.0000
n,150,2580.5,1999.0,0.0000
n,151,2795.5,1999.0,0.0000
n,152,3010.6,1999.0,0.0000
n,153,-1253.4,3125.7,0.0000
n,154,0.0000,1999.0,0.0000
n,156,-1169.8,3050.6,0.0000
n,157,-1086.3,2975.5,0.0000
n,158,-1002.7,2900.4,0.0000
n,159,-919.16,2825.2,0.0000
n,160,-835.60,2750.1,0.0000
n,161,-752.04,2675.0,0.0000
n,162,-668.48,2599.9,0.0000
n,163,-584.92,2524.8,0.0000
n,164,-501.36,2449.7,0.0000
n,165,-417.80,2374.6,0.0000
n,166,-334.24,2299.5,0.0000
n,167,-250.68,2224.3,0.0000
n,168,-167.12,2149.2,0.0000
n,169,-83.560,2074.1,0.0000
n,184,1253.4,3125.7,0.0000
n,186,1169.8,3050.6,0.0000
n,187,1086.3,2975.5,0.0000
n,188,1002.7,2900.4,0.0000
n,189,919.16,2825.2,0.0000
n,190,835.60,2750.1,0.0000
n,191,752.04,2675.0,0.0000
n,192,668.48,2599.9,0.0000
n,193,584.92,2524.8,0.0000
n,194,501.36,2449.7,0.0000
n,195,417.80,2374.6,0.0000
n,196,334.24,2299.5,0.0000
n,197,250.68,2224.3,0.0000
n,198,167.12,2149.2,0.0000
n,199,83.560,2074.1,0.0000
TYPE,2
MAT,2
SECNUM,2
REAL,2
e,122,124
*do,i,0,27,1
e,124+i,125+i
*enddo
e,152,123
e,153,156
*do,i,0,12,1
e,156+i,157+i
*enddo
e,169,138
e,184,186
*do,i,0,12,1
e,186+i,187+i
*enddo
e,199,138
allsel,all
FINISH
/SOL
D,1, , , ,0,UX,UY,uz, , , ,
D,33, , , ,0,UX,UY,uz, , , ,
F,66,FY,-130
F,95,FY,-130
F,79,FY,-170
F,108,FY,-170
F,63,FY,-190
ALLSEL,ALL
/STATUS,SOLU
NLGEOM,1
SOLVE
FINISH
ANSYS 技术邻杯ANSYS原创案例大赛
全部回答 (4)
Barnettt 2017年4月21日
我通过接点自由度耦合想把中间的杆件和外侧杆件联系起来可以吗,网上这么说行,但是我做的还是没有联系到一起
2017年4月21日
邹正刚 2017年4月21日
你这还是以前那个老问题呀。 以前的问题,中间三根杆与外围两根长杆没有连接到一起的问题解决了吗? 这次还是是约束不足。你可以为材料添加密度,然后做一次模态分析,抽取 10 个模态,看看是否有零频率。如果有零频率,则显示一下各零频率的模态形状,分析一下缺少什么约束。
2017年4月21日
邹正刚 2017年4月21日
你打开了大变形选项,则问题属于非线性分析。但是你的求解设置基本没有。至少需要设置一下求解的子步数、加载方式、自动时间步等。 另外,计算结束,无论是否正常结束,都可以看一下输出窗口和错误文件,看看有什么信息。如有警告或错误信息,可以分析原因,解决问题。
2017年4月21日
评论 4 点赞
技术工 2017年4月20日
@ANSYS专家 @水哥ANSYS @张小
2017年4月20日
相似问题
查看全部
  • 进行优化分析,设计变量有变化,但是状态变量没有变化,请帮忙看一下,优化分析部分的命令流有什么错误? 1个回答
    这是全部命令流,只看优化分析部分就行,问题就出在优化设计部分 finish /clear /filname,HERWDQ /title,BL !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!设计变量初值 E_x1=3.45E10 D_z1=2550 E_x2=3.45E10 D_z2=2550 E_x3=3.45E10 D_z3=2550 E_x4=3.
  • 进行优化分析时出错,不知道问题出在哪 暂无回答
    提示:modification of an optimization variable has forced a partial clear of your optimization on data.Design sets and global optimization settings are unchanged,but all other data has been initialized.
  • ansys线—线接触和线—面接触的间隙问题怎么处理? 1个回答
    你好,我用线-面接触和线-线接触分别模拟主缆钢丝与鞍槽接触和主缆钢丝与钢丝之间相互接触行为,钢丝与钢丝、鞍槽之间都有一定的间隙,钢丝之间存在5.25mm(钢丝直径)间隙,钢丝与鞍槽侧壁存在2.625mm(钢丝半径)间隙,因为钢丝与鞍槽的曲率半径不同,所以钢丝与鞍槽底面的间隙不清楚,具体的我把命令流和错误提示附上各位帮看一下。 命令流如下: finish$/clear$/prep7 !1.几何模型
推荐阅读
用户自定义场变量子程序USDFLD从入门到高级 (如何通过USDFLD实现本构模型参数随状态改变)
长江学渣 长江学渣
¥48
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
汽车模具工艺CAE分析
汽车模具工艺CAE分析
汽车-Albina 汽车-Albina
免费
十分钟快速进行电子产品结构设计方案评估
十分钟快速进行电子产品结构设计方案评估
技术邻直播 技术邻直播
免费
SolidWorks快速入门(操作+技巧+案例)试听课
宸格教育 宸格教育
免费
* starccm+制动盘旋转-冷却仿真(主体更新完成)
qqsww qqsww
¥199
AQWA软件企业培训(3)  通过ANSYS-APDL建立半潜平台混合模型及混合模型的拖曳力线性化
Nutshell Nutshell
¥30
场景仿真加速智能网联开发测试进程
场景仿真加速智能网联开发测试进程
海克斯康设计与仿真 海克斯康设计与仿真
免费
更智能的3D打印设计和工艺仿真应用网络研讨会
海克斯康设计与仿真 海克斯康设计与仿真
免费
ABAQUS复模态分析
ABAQUS复模态分析
tangxiaocao
¥50
基于OptiSturct的线性静力学分析和尺寸优化
Leon_sun Leon_sun
¥10
UG编程零基础入门到精通以及优化刀路教程
UG编程 UG编程
免费
