求解释ANSYS命令流? 50
浏览:1275 回答:7
finish
/prep7
*set,strd,90e6
esel,none
cm,bldam,elem
cm,bl1dam,elem
cm,bl2dam,elem
cm,bl3dam,elem
cm,bl4dam,elem
cm,bl5dam,elem
cm,bl6dam,elem
cm,bl7dam,elem
cm,bl8dam,elem
cm,bl9dam,elem
cm,bl0dam,elem
/post1
INRES,ALL
FILE,'XLD','rst','.'
set,1,1
cmsel,s,AAA,elem
*get,jcount,elem,0,count,
*get,jmin,elem,0,num,min
cmsel,s,AAA,elem
etable,,s,1
etable,,s,3
SADD,is,S1,S3,1,-1, ,
*do,i,120,126,1
set,1,i
ETABLE,REFL
*set,jv,1
*do,j,1,jcount,1
*set,jv,ELNEXT(jv)
*get,pos,elem,jv,etab,is
*if,pos,ge,0.1*strd,then
cmsel,s,bl1dam
esel,a,,,jv
cm,bl1dam,elem
*endif
*if,pos,ge,0.2*strd,then
cmsel,s,bl2dam
esel,a,,,jv
cm,bl2dam,elem
*endif
*if,pos,ge,0.3*strd,then
cmsel,s,bl3dam
esel,a,,,jv
cm,bl3dam,elem
*endif
*if,pos,ge,0.4*strd,then
cmsel,s,bl4dam
esel,a,,,jv
cm,bl4dam,elem
*endif
*if,pos,ge,0.5*strd,then
cmsel,s,bl5dam
esel,a,,,jv
cm,bl5dam,elem
*endif
*if,pos,ge,0.6*strd,then
cmsel,s,bl6dam
esel,a,,,jv
cm,bl6dam,elem
*endif
*if,pos,ge,0.7*strd,then
cmsel,s,bl7dam
esel,a,,,jv
cm,bl7dam,elem
*endif
*if,pos,ge,0.8*strd,then
cmsel,s,bl8dam
esel,a,,,jv
cm,bl8dam,elem
*endif
*if,pos,ge,0.9*strd,then
cmsel,s,bl9dam
esel,a,,,jv
cm,bl9dam,elem
*endif
*if,pos,ge,strd,then
cmsel,s,bl0dam
esel,a,,,jv
cm,bl0dam,elem
*endif
cmsel,s,AAA
*enddo
*enddo
finish
/prep7
MP,EX,2,5e10
MP,NUXY,2,0.22
MP,EX,3,5e10
MP,NUXY,3,0.22
MP,EX,4,5e10
MP,NUXY,4,0.22
MP,EX,5,5e10
MP,NUXY,5,0.22
MP,EX,6,5e10
MP,NUXY,6,0.22
MP,EX,7,5e10
MP,NUXY,7,0.22
MP,EX,8,5e10
MP,NUXY,8,0.22
MP,EX,9,5e10
MP,NUXY,9,0.22
MP,EX,10,5e10
MP,NUXY,10,0.22
MP,EX,11,5e10
MP,NUXY,11,0.22
cmsel,s,bl1dam
mpchg,11,all
cmsel,s,bl2dam
mpchg,2,all
cmsel,s,bl3dam
mpchg,3,all
cmsel,s,bl4dam
mpchg,4,all
cmsel,s,bl5dam
mpchg,5,all
cmsel,s,bl6dam
mpchg,6,all
cmsel,s,bl7dam
mpchg,7,all
cmsel,s,bl8dam
mpchg,8,all
cmsel,s,bl9dam
mpchg,9,all
cmsel,s,bl0dam
mpchg,10,all
/NUMBER,1
/PNUM,MAT,1
esel,all
eplot
/COLOR,NUM,BLAC,1
/COLOR,NUM,LGRA,2
/COLOR,NUM,CBLU,3
/COLOR,NUM,CYAN,4
/COLOR,NUM,GCYA,5
/COLOR,NUM,GREE,6
/COLOR,NUM,YGRE,7
/COLOR,NUM,YELL,8
/COLOR,NUM,ORAN,9
/COLOR,NUM,RED,10
/COLOR,NUM,DGRA,11
/REPLOT
(4)
韩罗峰
建议用help
2017年5月10日
张应迁
哦,明白了,那空了我把命令流读懂了再告诉你
2017年5月9日
张应迁
自己添加solve就可以了啊,关键是看前处理是否完成
2017年5月9日
不大不小谢
@有限元中解人生
2017年5月9日
