在分析中设置了多个分析布,但是每个分析不第一个结果输出不出来,怎么解决?
浏览:1448 回答:1
ABAQUS给出的建议是这个:
Mismatch detected between lengths of coordinates array and deformation array. This might occur when a user step contains mix of complex and non-complex frames. This feature is not supported currently. a work-around is to convert the non-complex data into complex data by adding imaginary components equal to 0.
具体要怎么解决呢?不解决的话多结果有没有什么影响
技术工
@晓月清风_mi@君莫@victor007
2017年5月19日
