求各路大神指点 dyna计算没有 N o r m a l t e r m i n a t ? 50
浏览:3943 回答:10
正常dyna计算应该有termination 这个计算怎么没有也没有产生错误,是否是时间步长的问题。
 E:\work\s\model\5-24\assem.key
 Open include file: 01_controls.k
 Open include file: 03_gravity.k
 Open include file: S_M_1.k
 Open include file: 02_rail_coarse.k
 *** Warning 10170 (KEY+170)
     duplicate node ID 5020422
     duplicate node ID 5021468
     duplicate node ID 5021469
     duplicate node ID 5091839
     duplicate node ID 5091840
     duplicate node ID 5091841
 *** Warning 10172 (KEY+172)
           6 duplicate nodes deleted
 *** Warning 10177 (KEY+177)
     nodal rigid body and part share the same ID 1
     nodal rigid body and part share the same ID 7
     nodal rigid body and part share the same ID 13
     nodal rigid body and part share the same ID 19
     nodal rigid body and part share the same ID 25
     nodal rigid body and part share the same ID 31
     nodal rigid body and part share the same ID 37
     nodal rigid body and part share the same ID 43
     nodal rigid body and part share the same ID 49
     nodal rigid body and part share the same ID 50
     nodal rigid body and part share the same ID 51
     nodal rigid body and part share the same ID 52
     nodal rigid body and part share the same ID 53
     nodal rigid body and part share the same ID 54
     nodal rigid body and part share the same ID 55
     nodal rigid body and part share the same ID 57
     nodal rigid body and part share the same ID 61
     nodal rigid body and part share the same ID 63
     nodal rigid body and part share the same ID 66
     nodal rigid body and part share the same ID 67
     nodal rigid body and part share the same ID 72
     nodal rigid body and part share the same ID 74
     nodal rigid body and part share the same ID 77
     nodal rigid body and part share the same ID 80
     nodal rigid body and part share the same ID 84
     nodal rigid body and part share the same ID 87
     nodal rigid body and part share the same ID 90
     nodal rigid body and part share the same ID 94
     nodal rigid body and part share the same ID 98
     nodal rigid body and part share the same ID 100
     nodal rigid body and part share the same ID 104
     nodal rigid body and part share the same ID 107
     nodal rigid body and part share the same ID 109
     nodal rigid body and part share the same ID 115
     nodal rigid body and part share the same ID 121
     nodal rigid body and part share the same ID 122
     nodal rigid body and part share the same ID 123
     nodal rigid body and part share the same ID 139
     nodal rigid body and part share the same ID 147
     nodal rigid body and part share the same ID 153
     nodal rigid body and part share the same ID 164
     nodal rigid body and part share the same ID 168
     nodal rigid body and part share the same ID 169
     nodal rigid body and part share the same ID 172
     nodal rigid body and part share the same ID 174
     nodal rigid body and part share the same ID 176
     nodal rigid body and part share the same ID 180
     nodal rigid body and part share the same ID 182
     nodal rigid body and part share the same ID 183
     Message 10177 (KEY+177) exceeds 50 times
     Further printing will be suppressed from screen only
     You can change the limit (MSGMAX) at field 4 of card 2 of *CONTROL_OUTPUT
 Memory required to process keyword     :    294083182
 *** Warning 21129 (STR+1129)
     shell element, ID= 71736 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.9936E-02
     which may be too small (< 0.1) to permit a stable calculation.
     shell element, ID= 75542 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.4949E-02
     shell element, ID= 75543 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.5098E-02
 *** Warning 20282 (STR+282)
     warpage angle of element ID= 1273441 is computed as 4.0980E+01 degrees.
     shell element, ID= 2169949 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.3599E-02
     shell element, ID= 2170119 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.6718E-02
     shell element, ID= 2170637 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.9153E-02
     shell element, ID= 2171062 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.8608E-02
     shell element, ID= 2171371 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.1302E-02
     shell element, ID= 2171496 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.3178E-02
     shell element, ID= 2171833 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 9.6692E-02
     shell element, ID= 2476517 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.3438E-02
     shell element, ID= 2476581 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.0407E-02
     shell element, ID= 2477298 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.0690E-02
     shell element, ID= 2549471 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.1710E-02
     shell element, ID= 2549901 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.3471E-02
     shell element, ID= 2549930 violates heuristic shape criterion
     area/(longest diagonal)/(longest diagonal) equals: 8.0441E-02
 *** Warning 20289 (STR+289)
     Number of elements exceed warpage angle = 1
       min warpage angle = 4.0980E+01
       max warpage angle = 4.0980E+01
 input of data is completed
 *** Warning 30226 (INI+226)
     node 1 (rigidwall 1) init. penetration= 4.0980E+01
     node 2 (rigidwall 1) init. penetration= 4.0980E+01
     node 3 (rigidwall 1) init. penetration= 4.0980E+01
     node 4 (rigidwall 1) init. penetration= 4.0980E+01
     node 5 (rigidwall 1) init. penetration= 4.0980E+01
     node 6 (rigidwall 1) init. penetration= 4.0980E+01
     node 7 (rigidwall 1) init. penetration= 4.0980E+01
     node 8 (rigidwall 1) init. penetration= 4.0980E+01
     node 9 (rigidwall 1) init. penetration= 4.0980E+01
     node 10 (rigidwall 1) init. penetration= 4.0980E+01
     node 11 (rigidwall 1) init. penetration= 4.0980E+01
     node 12 (rigidwall 1) init. penetration= 4.0980E+01
     node 13 (rigidwall 1) init. penetration= 4.0980E+01
     node 14 (rigidwall 1) init. penetration= 4.0980E+01
     node 15 (rigidwall 1) init. penetration= 4.0980E+01
     node 16 (rigidwall 1) init. penetration= 4.0980E+01
     node 17 (rigidwall 1) init. penetration= 4.0980E+01
     node 18 (rigidwall 1) init. penetration= 4.0980E+01
     node 19 (rigidwall 1) init. penetration= 4.0980E+01
     node 20 (rigidwall 1) init. penetration= 4.0980E+01
     node 21 (rigidwall 1) init. penetration= 4.0980E+01
     node 22 (rigidwall 1) init. penetration= 4.0980E+01
     node 23 (rigidwall 1) init. penetration= 4.0980E+01
     node 24 (rigidwall 1) init. penetration= 4.0980E+01
     node 25 (rigidwall 1) init. penetration= 4.0980E+01
     node 26 (rigidwall 1) init. penetration= 4.0980E+01
     node 27 (rigidwall 1) init. penetration= 4.0980E+01
     node 28 (rigidwall 1) init. penetration= 4.0980E+01
     node 29 (rigidwall 1) init. penetration= 4.0980E+01
     node 30 (rigidwall 1) init. penetration= 4.0980E+01
     node 31 (rigidwall 1) init. penetration= 4.0980E+01
     node 32 (rigidwall 1) init. penetration= 4.0980E+01
     node 33 (rigidwall 1) init. penetration= 4.0980E+01
     node 34 (rigidwall 1) init. penetration= 4.0980E+01
     node 35 (rigidwall 1) init. penetration= 4.0980E+01
     node 36 (rigidwall 1) init. penetration= 4.0980E+01
     node 37 (rigidwall 1) init. penetration= 4.0980E+01
     node 38 (rigidwall 1) init. penetration= 4.0980E+01
     node 39 (rigidwall 1) init. penetration= 4.0980E+01
     node 40 (rigidwall 1) init. penetration= 4.0980E+01
     node 41 (rigidwall 1) init. penetration= 4.0980E+01
     node 42 (rigidwall 1) init. penetration= 4.0980E+01
     node 43 (rigidwall 1) init. penetration= 4.0980E+01
     node 44 (rigidwall 1) init. penetration= 4.0980E+01
     node 45 (rigidwall 1) init. penetration= 4.0980E+01
     node 46 (rigidwall 1) init. penetration= 4.0980E+01
     node 47 (rigidwall 1) init. penetration= 4.0980E+01
     node 48 (rigidwall 1) init. penetration= 4.0980E+01
     node 49 (rigidwall 1) init. penetration= 4.0980E+01
     Message 30226 (INI+226) exceeds 50 times
 initial kinetic energy = 0.49793461E+05
 *** Warning 30313 (INI+313)
     Number of warning messages for rigid bodies
     Have a principal inertia at least 4 orders of magnitude apart=       30434
     2-noded nodal rigid body is deleted due to massless node     =           0
     Nodal rigid body deleted due to null inertia tensor          =           0
 *** Warning 30131 (INI+131)
     total number of massless nodes = 12307
 total nodal rigid body mass= 1.9200516E+00
 The LS-DYNA time step size should not exceed     1.500E-07
 to avoid contact instabilities.  If the step size is
 bigger then scale the penalty of the offending surface.
 Memory required to begin solution      :    659896221
 Additional dynamically allocated memory:    566751203
                                   Total:   1226647424
 initialization completed
 summary of initial penetration for interface #=          20
   number of warning messages                  =       13432
   number of penetrating nodes                 =       13432
   number of penetrating node eliminated       =           0
   min penetration distance                    =  5.1672E-02
   max penetration distance                    =  6.7359E+00
 calculation with mass scaling for minimum dt
    added mass   =   4.2077E-02
    physical mass=   1.2024E+02
    ratio        =   3.4994E-04
 dt of cycle       1 is controlled by dt2ms
 time...........................   0.00000E+00
 time step......................   8.00000E-07
 kinetic energy.................   3.75696E+04
 internal energy................   1.00000E-20
 stonewall energy...............   2.84913E+06 wall#    1
 spring and damper energy.......   1.00000E-20
 joint internal energy..........   0.00000E+00
 hourglass energy ..............   0.00000E+00
 system damping energy..........   0.00000E+00
 sliding interface energy.......   0.00000E+00
 external work..................   0.00000E+00
 eroded kinetic energy..........   0.00000E+00
 eroded internal energy.........   0.00000E+00
 eroded hourglass energy........   0.00000E+00
 total energy...................   2.88670E+06
 total energy / initial energy..   7.68643E+01
 energy ratio w/o eroded energy.   7.68643E+01
 global x velocity..............   2.08342E+01
 global y velocity..............   0.00000E+00
 global z velocity..............   0.00000E+00
 number of shell elements that
 reached the minimum time step..    0
       1 t 0.0000E+00 dt 8.00E-07 flush i/o buffers            05/24/17 16:08:42
       1 t 0.0000E+00 dt 8.00E-07 write d3plot file            05/24/17 16:08:42
 Deformable Spotwelds:
 total added spotweld mass            =   1.8207E-10
 percentage mass increase             =   1.5142E-10
 cpu time per zone cycle............       207 nanoseconds
 average cpu time per zone cycle....       319 nanoseconds
 average clock time per zone cycle..       312 nanoseconds
 estimated total cpu time          =   3864350 sec (    1073 hrs 25 mins)
 estimated cpu time to complete    =   3863620 sec (    1073 hrs 13 mins)
 estimated total clock time        =   3772979 sec (    1048 hrs  2 mins)
 estimated clock time to complete  =   3772249 sec (    1047 hrs 50 mins)
 added mass          =   5.5561E-02
 percentage increase =   4.6208E-02
 termination time                  = 2.000E+00
(6)
奈文摩尔
是的,模型有问题,dupulicate点都报出来了,找找相关的part看看
2017年5月25日
评论 点赞 1
TechmanLXS
这是初始化的预估,你等他跑一下再估一下。
2020年9月23日
愿随风散去
老哥,问题解决了吗,是哪里出错了,我似乎碰到一样的问题了
2020年9月23日
FEM小生
你的模型估计重合面或者重合点之类的太多了吧,导致计算时间很长。而且你的网格我猜你是自动划分的吧,网格质量很差。
2017年5月25日
周游
你这个显示1000加的小时还能正常结束啊,模型问题应该不小
2017年5月24日
已采纳 评论 2 点赞
技术工
@dyna_focus @蓝牙@奈文摩尔
2017年5月24日
