ABAQUS子程序验证不通过,如何解决? 40
浏览:3762 回答:9
子程序验证报告如下:
Abaqus Product Install Verification...
Thu Jun 15 18:18:20 2017
Running system requirement checks.
Requirement:    Windows Server 2003, Windows Server 2008, Windows Server
                2008 R2, Windows HPC Server 2008, Windows XP, Windows Vista,
                or Windows 7
Product:        All Abaqus Products
Status:         Pass - Found Windows 7 Professional Service Pack 1 (Build
                7601) (x64).
Requirement:    Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product:        Abaqus make utility with C++
Status:         Fail - Unable to locate or determine the version of a C++
                compiler on this system.  If Microsoft Visual C++ 8.0 (.NET
                2005) is installed on this system, please load
                vcvarsamd64.bat file before running Abaqus.
Requirement:    Intel Fortran Compiler 10.1, or 11.1
Product:        Abaqus make utility with Fortran and Abaqus with user
                subroutines
                Fortran compiler on this system.  If Intel Fortran is
                installed on this system, please load ifortvars.bat before
                running Abaqus.
Requirement:    MS-MPI 2.0, 3.0 or greater
Product:        Abaqus analyses using MPI-based parallelization and
                Abaqus/CFD
Status:         Pass - Found MS-MPI 2.1.1765.0.
Requirement:    Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
                3.5 or greater
Product:        Abaqus Documentation
Status:         Pass - Found Internet Explorer 10.0.9200.17457
Found D:\Temp\verify.  All verification files will reside in this directory.
Old job files exist.  They will be moved to verifyOLD.
Abaqus/Standard
         ...PASS
         Continuing...
Abaqus/Standard with user subroutines
         ...INFORMATION
            System requirements were not met. Verification
            procedure will be skipped. However, user subroutines
            can be run using a precompiled library set by the
            variable usub_lib_dir. For more information please
            see the section 3.2.2 of Abaqus Analysis User's
            Manual.
         Continuing...
Abaqus/Explicit (single precision)
         ...PASS
         Continuing...
Abaqus/Explicit (double precision)
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (single precision)
         ...INFORMATION
            Manual.
         Continuing...
Abaqus/Explicit with user subroutines (double precision)
         ...INFORMATION
            Manual.
         Continuing...
Abaqus/Viewer
         ...PASS
         Continuing...
Abaqus/CAE
         ...PASS
         Continuing...
Geometry Translator for CATIA V4
         ...PASS
         Continuing...
Geometry Translator for CATIA V5
         ...PASS
         Continuing...
Direct Geometry Import for CATIA V5
         ...ERROR
            Geometry translation failed.  Please see
            DirectCATIAv5.rpy for details.
         Continuing...
Geometry Translator for I-DEAS
         ...PASS
         Continuing...
Geometry Translator for Parasolid
         ...PASS
         Continuing...
Geometry Translator for Pro/ENGINEER
         ...PASS
         Continuing...
SolidWorks Associative Interface
         ...PASS
         Continuing...
Abaqus/AMS
         ...PASS
         Continuing...
Abaqus Interface for MSC.ADAMS
         ...PASS
         Continuing...
Abaqus/Standard parametric studies
         ...PASS
         Continuing...
Abaqus/Explicit parametric studies
         ...PASS
         Continuing...
Abaqus/Design
         ...PASS
         Continuing...
Abaqus Interface for Moldflow
         ...PASS
         Continuing...
         ...INFORMATION
         Continuing...
         ...INFORMATION
         Continuing...
Abaqus make utility with object code
         ...INFORMATION
         Continuing...
Abaqus scripting interface
         ...PASS
         Continuing...
Abaqus analyses using parallelization
      Running thread-based parallel with 2 cpu(s)
            Abaqus/Explicit domain-level parallel
         ...PASS
            Abaqus/Standard direct solver
         ...PASS
         Continuing...
Abaqus/Foundation
         ...PASS
         Continuing...
Abaqus noGUI (CAE/Viewer)
         ...PASS
         Continuing...
Abaqus/CFD
         ...PASS
         Continuing...
Clean-up...
Job files exist. Verification directory D:\Temp\verify will not be deleted.
烦请大神指导
易炜
需要添加path 和 include的环境变量
2017年6月16日
评论 3 点赞
微信公众号:FILWTBY
Abaqus6.14安装教程以及如何关联子程序
http://www.jishulink.com/college/video/c10796?SUID=ccb184b5-1840-4238-bda7-092a1ff61ca2
如果是6.14可以看一下这个
2017年6月15日
评论 2 点赞
微信公众号:FILWTBY
哪个版本
2017年6月15日
