riks疑问,解决有偿? 200
浏览:1052 回答:4
A zero displacement solution was found in the first iteration of a riks step. The analysis cannot proceed. The most likely cause is that all displacement degrees-of-freedom are constrained to be zero.
求解决方案?是由于不收敛造成的吗
