ls-dyna信息中出现的是这种错误?
浏览:2340 回答:2
 Error 41268 (SOL+1268)
     The denominator in eos_4 is close to zero.
     The volume fraction of the ALE group 2 in the
     element 261380 is modified from 7.675047E-04 to
     7.643695E-06
上面信息是我的计算信息中出现的,到了这一步之后,计算时间就卡住不动了,下面贴上的我k文件(省略了局部)
*CONTROL_ALE
$#     dct      nadv      meth      afac      bfac      cfac      dfac      efac
         3         3         1 -1.000000     0.000     0.000     0.000     0.000
$#   start       end     aafac     vfact      prit       ebc      pref   nsidebc
     0.0001.0000E+20  1.000000     0.000         0         0     0.000         0
$#    ncpl      nbkt    imascl    checkr
         1        50         0     0.000
*CONTROL_BULK_VISCOSITY
$#      q1        q2      type     btype
  1.500000  0.060000         1         0
*CONTROL_ENERGY
$#    hgen      rwen    slnten     rylen
         1         2         2         1
*CONTROL_HOURGLASS
$#     ihq        qh
         1  0.100000
*CONTROL_SHELL
$#  wrpang     esort     irnxx    istupd    theory       bwc     miter      proj
 20.000000         1        -1         1         2         2         1         0
$# rotascl    intgrd    lamsht    cstyp6    tshell    nfail1    nfail4   psnfail
  1.000000         0         0         1         0         0         0         0
$# psstupd    irquad     cntco    itsflg    irquad
         0         0         0         0         2
*CONTROL_TERMINATION
$#  endtim    endcyc     dtmin    endeng    endmas
 10000.000         0     0.000     0.000     0.000
*CONTROL_TIMESTEP
$#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
     0.000  0.900000         0     0.000     0.000         0         0         0
$#  dt2msf   dt2mslc     imscl
     0.000         0         0
*DATABASE_BINARY_D3PLOT
$#      dt      lcdt      beam     npltc    psetid
 250.00000         0         0         0         0
$#   ioopt
         0
*DATABASE_BINARY_D3THDT
 250.00000         0         0         0         0
*DATABASE_FORMAT
$#   iform   ibinary
         0         0
*DATABASE_EXTENT_BINARY
$#   neiph     neips    maxint    strflg    sigflg    epsflg    rltflg    engflg
         0         0         3         1         1         1         1         1
$#  cmpflg    ieverp    beamip     dcomp      shge     stssz    n3thdt   ialemat
         0         0         4         1         1         1         2         0
$                         INITIAL VELOCITY DEFINITIONS                         $
$# nintsld   pkp_sen      sclp    unused     msscl     therm    intout    nodout
         0         0  1.000000         0         0         0STRESS    STRESS
*BOUNDARY_NON_REFLECTING
$#    ssid        ad        as
         1     0.000     0.000
         2     0.000     0.000
*BOUNDARY_SPC_SET
$#    nsid       cid      dofx      dofy      dofz     dofrx     dofry     dofrz
         1         0         0         1         0         1         0         1
*PART
$# title
Part          1 for Mat         1 and Elem Type         1
$#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
         1         1         1         1         1         0         0         0
*SECTION_SOLID_ALE
$#   secid    elform       aet
         1        11         1
$#    afac      bfac      cfac      dfac     start       end     aafac
     0.000     0.000     0.000     0.000     0.000     0.000     0.000
*MAT_NULL
$#     mid        ro        pc        mu     terod     cerod        ym        pr
         1  1.020000-1.000E-10     0.000     0.000     0.000     0.000     0.000
*EOS_GRUNEISEN
$#   eosid         c        s1        s2        s3     gamao         a        e0
         1  1.480000  1.920000 -0.096000     0.000  0.350000     0.000     0.000
$#      v0
     0.000
*HOURGLASS
$#    hgid       ihq        qm       ibq        q1        q2    qb/vdc        qw
         1         1  0.100000         1  1.500000  0.060000  0.100000  0.100000
*PART
$# title
Part          2 for Mat         2 and Elem Type         2
         2         2         2         2         1         0         0         0
*SECTION_SOLID_ALE
$#   secid    elform       aet
         2        11         1
*MAT_NULL
         2  0.001250-1.000E-11     0.000     0.000     0.000     0.000     0.000
*EOS_GRUNEISEN
         2  0.344000     0.000     0.000     0.000  1.400000     0.000     0.000
$#      v0
     0.000
*PART
$# title
Part          3 for Mat         3 and Elem Type         3
         3         3         3         0         1         0         0         0
*SECTION_SOLID
$#   secid    elform       aet
         3         1         0
*MAT_FHWA_SOIL
$#     mid        ro     nplot    spgrav    rhowat        vn    gammar    intrmx
         3  1.980000         1  2.720000  1.000000     0.000     0.000         1
$#       k         g    phimax      ahyp       coh     eccen        an        et
 5.0000E-6 6.0000E-8  0.100000 2.9800E-8 3.6000E-7  0.700000     0.000     0.000
$#   mcont      pwd1     pwksk      pwd2    phires      dint      vdfm    damlev
  0.230000     0.000     0.000     0.000  0.034000  0.025000  0.050000     0.000
$#  epsmax
  0.300000
*MAT_ADD_EROSION
$#     mid      excl    mxpres     mneps    effeps    voleps    numfip       ncs
         3 1234.0000     0.000     0.000     0.000     0.000  1.000000  1.000000
$#  mnpres     sigp1     sigvm     mxeps     epssh     sigth   impulse    failtm
 1234.0000 1234.0000 1234.0000 1234.0000  0.400000 1234.0000 1234.0000 1234.0000
d**id wang_QTwl
兄弟 解决了吗 我也出现了这个问题,困扰了我好几天
2020年11月3日
