workbench 模态分析出错怎么解决啊?
浏览:2129 回答:2
错误信息:Eigenvalue extraction failed since the allocated storage for
eigenvalues was exceeded.  This occurred while searching for converged
eigenvalues either within a specified range or about a center value
with a begin frequency of FREQB= 0.  Changing the beginning and/or end
frequency values on the MODOPT command may help avoid this error.
怎么解决呀
技术邻问答
如果觉得回答有帮助,请记得及时采纳哦
2017年11月16日
TQT-CAE
检查模态分析起始频率
2017年9月1日
