ANSYS报错Key point is associated with node cannot? 40
浏览:1510 回答:2
ANSYS导入命令流时报错Key point 1 is associated with node 160 and cannot be changed是怎么回事?如何修改模型?
命令流如下:
/batch
/com,ansys release 14.0    up20111024       20:05:53    09/04/2017
/gra,power
/gst,on
/plo,info,3
/gro,curl,on
/cplane,1
wpstyle,,,,,,,,0
save,'rout4','db','c:\users\administrator.pc-20130802pbxq\'
*set,l,18
*set,h,5
*set,h1,3
*set,l1,13
*set,l2,3
*set,et,3.2e7
*set,rout,2110
*set,ej,3e6
*set,rouj,1900
/prep7
et,1,42
keyopt,1,1,0
keyopt,1,2,0
keyopt,1,3,2
keyopt,1,5,0
keyopt,1,6,0
mptemp,,,,,,,
mptemp,1,0
mpdata,ex,1,,et
mpdata,prxy,1,,0.3
mptemp,,,,,,,
mptemp,1,0
mpdata,dens,1,,rout
tb,dp,1,,
tbmodif,1,1,110e3
tbmodif,1,2,30
tbmodif,1,3
mptemp,,,,,,,
mptemp,1,0
mpdata,ex,2,,ej
mpdata,prxy,2,,0.35
mptemp,,,,,,,
mptemp,1,0
mpdata,dens,2,,1900
tb,dp,2,,
tbmodif,1,1,30e3
tbmodif,1,2,25
tbmodif,1,3
k,1,0,0,0
k,2,l,0,0
k,3,l,h,0
k,4,l,h+h1,0
k,5,l-l2,h+h1,0
k,6,l1,h,0
k,7,0,h,0
ksel,s,kp,,1
ksel,a,kp,,2
ksel,a,kp,,3
ksel,a,kp,,6
ksel,a,kp,,7
a,all
ksel,s,kp,,3
ksel,a,kp,,4
ksel,a,kp,,5
ksel,a,kp,,6
a,all
esize,0.3,0
type,1
mat,1
real
esys,0
secnum
mshape,0,2d
mshkey,0
asel,,,,2
amesh,all
type,1
mat,2
real
esys,0
secnum
asel,,,,1
amesh,all
finish
/sol
antype,0
nlgeom,1
nropt,full,
staopt,defa
lumpm,0
eqslv,,,0,,dele
msave,0
pcgopt,0,,auto,,,auto
pivcheck,1
pstress,0
toffst,0
finish
/prep7
lsel,s,line,,2
lsel,a,line,,5
/go
dl,all,,ux
lsel,s,line,,1
/go
dl,all,,all
finish
/sol
acel,0,-9.8,0
/status,solu
solve
TQT-CAE
ANSYS中带有网格的点、线、面、体,都是不允许修改的
2017年9月4日
