abaqus中.sta文件这些关于接触的话什么意思呀,看的模模糊糊不是太理解?
浏览:2313 回答:2
INFORMATION REGARDING INITIAL CONTACT PAIR OVERCLOSURES THAT Abaqus/Explicit
  WILL ATTEMPT TO RESOLVE WITH STRAIN-FREE ADJUSTMENTS TO POSITIONS OF
  DEFORMABLE
  SLAVE NODES Step   1
  Maximum overclosure between surface ASSEMBLY_SURF-PIN and surface
  ASSEMBLY_SURF-DISC is 1.62371E-02.
Maximum adjustment for initial overclosure is: 1.62371E-02 at node 12 of instance XINPIN_R80.
***NOTE: You can view the deformed configuration due to the resolution of
         initial overclosures.  In increment 0, draw the deformed shape or
         draw a symbol plot of vector displacements.
More detailed overclosure adjustment information can be found in the message file.
  INFORMATION REGARDING UNRESOLVED INITIAL CONTACT PAIR OVERCLOSURES FOR
  SLAVE NODES Step   1
***WARNING: For contact pairs that are not tied, unresolved initial
            overclosures will result in initial accelerations on the order of
            the penetration distance divided by the time increment squared,
            which can lead to significant mesh distortion. These overclosures
            can be avoided by user adjustment of the mesh.
  ASSEMBLY_SURF-DISC is 2.87868E-19.
技术邻问答
如果觉得回答有帮助,请记得及时采纳哦
2017年11月16日
叶重
过盈接触 说白了就是接触设置的不对,abaaus无法收敛
2017年9月7日
